Problem with the panel light
Old Oct 1, 2017
Joan R. Santana's Avatar
Joan R. Santana is an unknown quantity at this point
Well i have a problem with the light of my Ep3 , is not turning on the light of the A/C thing , not the A/C buttons , the wheels that you adjust the air and the heat and those thing i dont know why , i already change the bulbs and nothing i tried to find the fuse but i just cant find it , if someone can help me , i will be very very happy !
Old Oct 1, 2017
Re: Problem with the panel light
Heater control panel.....the unit next to the radio....
Those bulbs share the same fuse as the rest of the lights in the gauges/cruise/hazard/AC/defog/stock radio, so if those all work then it's not a fuse issue.
You took it apart and replaced the little bitty bulbs behind that panel?
Did you check if the bulbs were actually good before you installed them?
If you have a voltmeter you could check if each bulb mount is getting proper power and ground
Bulb is item #1, the parts catalog says there should be two of them in the unit:
Old Oct 5, 2017
i check everything and the heater control panel is all good , but i noticed the bulbs from the A/C buttons. both are blown
