Headlight trouble
Old Jun 9, 2017
Bradygc's Avatar
Bradygc is an unknown quantity at this point
Headlight trouble
Hey guys, I am new here so forgive me if I'm not doing this whole forum thing right. Anyways, I recently bought a 2002 Civic LX Sedan as my first car. A month ago, I noticed my drivers side headlight was not working. It will work when the car is not started (key in the "II" slot), but as soon as I turn the car on and the headlights on, the drivers side one goes out. DRL works fine, but when I flick the high beam switch, it goes out. I have already changed the headlight and put a fuse in and still nothing, which leads me to believe it's a grounding issue. Any help will be appreciated! Just tryna keep my first car for a long time
Old Jun 10, 2017
mac25's Avatar
Dr Krieger of Modification
Re: Headlight trouble
Did you check the under dash fuses as well?
Old Jun 10, 2017
Bradygc's Avatar
I have, and I'm not quite sure what fuse it would be even after looking at the diagram on the panel door
Old Jun 13, 2017
mac25's Avatar
You're going to have to get a Hayness manual, trace the diagram back from the lights to the issue, with a multimeter and test light.
