Dome light wont come on unless key in ignition
Old Jan 24, 2015
izedali's Avatar
izedali is an unknown quantity at this point
Post Dome light wont come on unless key in ignition
can anyone help please.
My dome light doesn't come on when i open any door or even the hood or boot, but when i enter the key into the ignition it comes on and stays on, and when i take the key out it takes about 5 mins to turn off.
thanks
Old Jan 24, 2015
CraigW's Avatar
Re: Dome light wont come on unless key in ignition
What year ?
Old Jan 24, 2015
RIPSAW's Avatar
RIPSAW has a spectacular aura aboutRIPSAW has a spectacular aura about
Think the last part about it cutting off is correct. Sounds like your little pokey in and out switch may may be bad down on the door jam. Is it stuck in?
Old Jan 24, 2015
CraigW's Avatar
Yes, timing out.
Forgot about that.
Somehow staying grounded.
Old Jan 24, 2015
RIPSAW's Avatar
Ungrounded I think?
Old Jan 24, 2015
CraigW's Avatar
The pin switches to ground with door open.
Old Jan 24, 2015
izedali's Avatar
Arrow Re: Dome light wont come on unless key in ignition
its 2002 imagine cdti
Old Jan 24, 2015
izedali's Avatar
Smile Re: Dome light wont come on unless key in ignition
but the light doesnt react if the doors are open or not, only when i insert the key into ignition, but isnt it suppose to normally go off at that point instead of coming on
Old Jan 24, 2015
CraigW's Avatar
When it comes on and stays on (after timing out) and then stays on until it times out again after key out...... leads me to think the system constantly sees a door as being open.
Pull your pin switches and inspect them. Leave them hanging out and see if symptoms change.
Old Jan 24, 2015
izedali's Avatar
yeah ill try that tomorrow, n ill update on it, nice 1
Old Mar 3, 2015
izedali's Avatar
Angry Re: Dome light wont come on when doors are open
ive tried hanging all of them out and it still the same issue, i even swapped the two front switches around but to no effect. the thing is my new fob doesnt work either as the system thinks the doors are open.
Old Mar 5, 2015
izedali's Avatar
Old Mar 5, 2015
CraigW's Avatar
Do you have unlock from fob ??
Do you get headlights on warning from drivers door ??
Old Mar 5, 2015
izedali's Avatar
yea fob opens the doors but doesnt lock it and no headlight warning
Old Mar 5, 2015
CraigW's Avatar
Does the dome go off when doors are closed, and the engine is started ??
Any other strange symptoms with the car ??
Old Mar 5, 2015
izedali's Avatar
na inside lights stays off when door is open but turns on when i insert the key into the ignition and stays on till i remove the key.
Old Mar 5, 2015
CraigW's Avatar
Does it stay on when the engine is running and doors closed then ??
Old Mar 5, 2015
izedali's Avatar
yea it stays on...
Old Mar 5, 2015
CraigW's Avatar
Well......the dome is under the control (and still is) of the MICU/Body computer inside the under-dash fuse box, based on it's inputs.
Do you own a DMM ??
Old Mar 5, 2015
izedali's Avatar
Wats dmm
Old Mar 5, 2015
RIPSAW's Avatar
Google says it an outfit that makes fancy climbing equipment. It is a bear to get up there but?! HA
beveragemp
May 25, 2015 07:11 PM
twtron
Apr 17, 2015 12:09 AM
SatinSilver2k1
Dec 10, 2001 09:54 PM
meels808
Nov 5, 2001 09:15 AM
TropiKalCiviC
Sep 25, 2001 07:02 PM
