Question about Morimoto Mini Retrofit?
Old Apr 26, 2014
Jomodeere's Avatar
Jomodeere is an unknown quantity at this point
Hey everyone,
Just bought a Silver 2002 EM2 with 92,xxx miles. I am wanting to upgrade the lighting situation and was looking at retrofitting.
This is the kit:
http://www.theretrofitsource.com/com...l#.U1u1xVcvCJg
I was wondering if I have to use the H1 HID bulbs or can I use the regular H4 HID bulbs?
Also, if using the H1 bulbs and ballasts how does it connect to my stock harness from the old H4 bulb?
Thanks for the help in advance!
Old Apr 26, 2014
GolNat's Avatar
Prelude Owner
Re: Question about Morimoto Mini Retrofit?
H1 bulbs are the ones that fit into the mini's.
You need to also order a relay harness. The relay harness will have all the necessary connectors needed to plug your OE wiring into the new bulbs and into the projector's coil to activate the high beams.
Old Apr 26, 2014
Jomodeere's Avatar
Okay that makes sense!
Let me make sure I am correct on this:
I buy the Morimoto Mini Projectors,
these bulbs and ballasts:
http://www.theretrofitsource.com/hid...l#.U1vfy1cvCJg
and finally, this harness:
http://www.theretrofitsource.com/com...l#.U1vgc1cvCJg
and I should be all set?
JMKendrick
Sep 16, 2015 06:17 PM
junkyardguy
Sep 2, 2015 06:07 PM
