Interior dome light dont work
Old Apr 20, 2014
sgibbs2014's Avatar
sgibbs2014 is an unknown quantity at this point
Hello,
I am new to this forum and I am a new owner of a 2004 Honda Civic VP and I have an issue with my interior dome light. I brought a new bulb and it didn't work. Then I checked the fuse (#3 fuse in engine compartment 7.5A) and replaced the fuse, still no light. I am like WTF is going on with this. This is a base model Value package Civic. Anyone else have or had this or a similar issue with this?
Old Apr 20, 2014
Re: Interior dome light dont work
Test in the light socket.
Is there 12v power on one side? Is there a ground on one side?
Old Apr 21, 2014
GolNat's Avatar
Prelude Owner
I had a similar issue with my dome light. Used my multimeter to determine that I was not getting any voltage at the bulb. I took the dome light completely apart and did a continuity test and found my switch wasn't making a connection from it being worn. Cleaned the switch mechanism and everything is working fine but it may need replacing in the future just from use.
Take it apart and see what you can find.
Old Apr 27, 2014
sgibbs2014's Avatar
Thanks I will test it to see if it's even receiving power. Good advice.
Old May 30, 2014
sgibbs2014's Avatar
I know I'm late but it was the actual housing. I ordered another piece and it took me less than a minute to put the new one back in. Its works like normal now.
ORskier
May 3, 2015 12:54 PM
twtron
Apr 17, 2015 12:09 AM
wawacito
Nov 5, 2001 03:32 PM
meels808
Nov 5, 2001 09:15 AM
TropiKalCiviC
Sep 25, 2001 07:02 PM
