Blower motor not working after I installed new radio
Old Nov 3, 2013
Barbin15x's Avatar
Barbin15x is an unknown quantity at this point
Basically says it all in the title I checked every fuse under the hood and kick panel everything looks great. I have no clue what it could be everything is plugged in no fan motor no lights to the bottom 3 buttons but I still have my hazards I've looked a forum after forum nothing is helping its 27 degrees tonight I need heat. Is there a relay that I should check? This is very annoying I've installed a ton of radios never had an issue before?
Thanks please help
Old Nov 3, 2013
Re: Blower motor not working after I installed new radio
Sounds like you didn't get at least one of the plugs reconnected all the way for the HVAC controls.
Just a guess.
Old Nov 4, 2013
Barbin15x's Avatar
I used a wire harness and connected everything the right way and you can't mix up the plugs just stumped I have no clue what it could be unless somthing shorted out
Old Nov 4, 2013
CraigW's Avatar
You did re-check the connectors in the pod.... yes ?
If you select rear defrost, does the led light ??
Is your connection to your blower fan and the transistor still intact ??
Old Nov 4, 2013
Barbin15x's Avatar
Yes I rechecked the connections
The blower fan and transistor are still intact
And when I hit the rear defrost the light does not come on
Old Nov 4, 2013
CraigW's Avatar
Double check Fuse #14(10A) in under dash box. Replace it, spares in lid under hood box.
Leave key at II engine off and move the face/floor/def **** and listen for noises from the dash when doing so.
Old Nov 4, 2013
Barbin15x's Avatar
Just wanted to say thank you it was the the number 14, 10 amp fuse, for some reason it wasn't pushed in all the way
And thank you to everyone else chimed in
Old Nov 5, 2013
CraigW's Avatar
ORskier
May 3, 2015 12:54 PM
bsmiley
Apr 27, 2015 01:27 PM
tylerginevan
Apr 27, 2015 12:29 PM
TheCrimsonKing
Engine start problems
Apr 25, 2015 09:40 PM
Ian SFBA
Interior DIY
Apr 25, 2015 02:25 PM
