I CANT SEE! Behind Me. . .
Old Mar 16, 2013
Hensinger2010's Avatar
Meh...
Hensinger2010 will become famous soon enough
I own a 03 Honda civic ex coupe/ auto, with a 03 ex sedan manual cluster in it,i neglected to notice the first couple months, that i don't have reverse lights, and i hate myself for not understanding this before i put the cluster in, anything i can do to solve this correctly and get my reverse lights back without switching the clusters, i understand the gear sensor is the problem, how do i solve? any information would be appreciated, thanks
Old Mar 16, 2013
Re: I CANT SEE! Behind Me. . .
(I'm running with the first wire diagram I see here, so bear with me.)
I think you will have to jumper 2 wires at the gauge connector.
There are 2 possibilities I'm seeing here, since this diagram covers more than one version of the car.
B connector is the light blue one
White wire, terminal B6 (or B11)
needs jumped to
Green/Black wire terminal B18 (or B4).....another diagram shows this wire as white too, so be careful.
Another diagram shows it Should be B6 to B18. Wht to Grn/blk....Check.
This should reconnect the Trans Range Switch Reverse terminal to the A/T Reverse Relay, bypassing the gauge cluster.
Usual disclaimer:
Get yourself a wiring diagram and make sure before doing anything, and test accordingly so you don't smoke the cluster (or something else) and try to blame me later!
Old Mar 16, 2013
Meh...
appreciated, ill look up diagrams when i have the chance, doesnt seem too difficult,
Old Mar 17, 2013
Meh...
good enough? after i confirm with my cluster ofcourse.
Last edited by Hensinger2010; Mar 17, 2013 at 02:14 AM. Reason: because he did it too!
Old Mar 17, 2013
Looks like the same page I had.
Old Mar 17, 2013
Meh...
then where is the confusion? should be a straight b6 to b18, with the exception of confusion from b17 i dont understand how it could be anything different.
Old Mar 17, 2013
Originally Posted by Hensinger2010
the where is the confusion? should be a straight b6 to b18, with the exception of confusion from b17 i dont understand how it could be anything different.
Got you thinking on your own, huh?
Does it work?
Old Mar 17, 2013
Just now saw this
Last edited by Hensinger2010; 11 Hours Ago at 02:14 AM. Reason: because he did it too!
I LOL'd.
Good to know someone actually looks at that stuff.
Old Mar 17, 2013
Meh...
could you post that other diagram you have?
Old Mar 17, 2013
Sorry man, I'm looking at factory wiring diagrams and cannot hotlink to them, and you'd have to have a subscription to see them.
Old Mar 17, 2013
Meh...
ahh, understandable, regardless i appreciate your help, just dont understand what the circuit m34 is and trying to figure it out before i splice. unless its the Trans Range Switch Reverse Terminal and the A/T Reverse Relay as you stated before. but the gear position indicator has nothing to do with it?
Old Mar 17, 2013
Ignore the M34. It is only a name given to that particular circuit.
Like "M35" is the circuit that contains the "P"ark indicator light in the cluster.
Old Mar 17, 2013
Meh...
alright thanks again, my apologies, im setting up a system for a galant right now, ill check the civic when i get some time. will check back tomorrow.
Zygrene
Mar 22, 2016 12:36 PM
2002ExCivic
22
Sep 28, 2015 08:29 AM
beanhead
Sep 24, 2015 12:04 PM
TheRiddicles
Sep 21, 2015 03:34 PM
Groundhog66
Sep 16, 2015 07:59 PM
