Aftermarket OEM Foglights would not turn on
Subscribe
Aug 29, 2011
Hi a couple of days ago i bought a pair of OEM foglights for my 2003 honda civic ex and i installed them according to the instructions from Honda. i installed the wires, properly grounded the wires, and installed the housing and lights. the kit came with wiring harness (which has the relay and fuse), the foglights, the OEM switch, and a 1-pin connector for the fuse box. the harness came with wiring that connects to the battery as well. there was a grounding wire that came with the connector for the fuse box. can anyone help me out with this problem? im thinking that the fuse plug needs a switch
Reply 0
Mar 6, 2012
Re: Aftermarket OEM Foglights would not turn on
i am having a very similar issue! what kind of fog lights did u buy? and which wires did u hook up in the car of the relay and the switch? should be a red and yellow wire no? bc thats what im having trouble with.. not sure what wires to go to of the headlight plug
Reply 0
Mar 6, 2012
Red/yellow is the + wire that goes to pin 86 on your relay. 85 to ground, 87 to battery with fuse and 30 to positive on fog lights.
Reply 0
Subscribe
