HID Wiring harness Relay question
Old May 24, 2011
TFMEX's Avatar
CO&CA
TFMEX is a jewel in the roughTFMEX is a jewel in the roughTFMEX is a jewel in the rough
So I bought 2 relay harnesses and it seems that the Relays were cheap and didnt last. They are constantly drawing on my battery while the car is off (2Amps). I have done some metering and came to the conclusion that the switches in the relays are sticking as if I turn the lights on and off I can get there to be no draw.
also my high beams turned on today by themselves and didnt turn off when I turned the car off..... I had to pull the power wire of the harness off the battery....
Any suggestions?
I obv need to replace the relay but need to know what kind. I know its a 40amp Automotive relay is there anything else I need to know? 4 or 5 prong? I also need the female piece as well as the one in the harness now does not have 2 separate pieces.
where can I find a good quality relay?
Old May 24, 2011
Shift-E's Avatar
That Dude with the Questions
Re: HID Wiring harness Relay question
I'm building my own Wiring harness right now with help from Gearbox. I bought a Bosch 5 pin relay (even though i only use 4). It was around 8 bucks from a local automotive parts place. Gearbox has been using his Bosch relay for over a year and he says he has had no problems with it.
I hoe that helps.
Any suggestions?
Old May 24, 2011
TFMEX's Avatar
CO&CA
Yeah looks like NAPA carries what I need. Thanks man!
Hope this fixes the power draw issue.
Old May 24, 2011
stick with bosch/tyco relay but it sounds like you may have other wiring issues if hi beams are coming on by themselves. www.partsexpress.com has everything you need to build your own harness. i would never use the cheapo premade harness they sell on ebay and stuff.
Old May 25, 2011
TFMEX's Avatar
CO&CA
I figured it was a relay sticking and not fully opening or closing causing the issue.
any insight would be very helpful
Old May 25, 2011
well it depends on your setup. i am imagining the relay is only for the hids and not the hi beams. it looks like you have an 04-05 so the hi beams should be halogen and completely separate from the new harness for the hid lo beams. hi beam wiring should not be touched unless you have a bixenon projector.
Old May 26, 2011
electric130's Avatar
I'd get one with a suppressing diode in it. I made a thread on why they're important.
https://www.civicforums.com/forums/1...ighlight=diode
Old May 26, 2011
TFMEX's Avatar
CO&CA
Relays got fried.... I have the Hi and lows on separate relay harnesses and the relays are not the best quality apparently. They got wet, fried and need to be replaced.
Old May 26, 2011
if they got wet, i would figure out a way for that not to happen like move them somewhere else. bosch relay can fail from getting wet too...be sure to mount them with the contacts/terminals facing down at the ground.
Old Jun 1, 2011
TFMEX's Avatar
CO&CA
after doing some more research I decided to not install the HID kit and stick with the Halogen bulbs. To many issues with power consumption and im not getting the light output I thought I would. The halogens actually are brighter than the 6K HID bulbs.....
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
CarStuff
Dec 6, 2020 12:52 PM
Jon-Ohio
Jun 30, 2018 08:10 PM
nicholaai
Apr 27, 2015 05:54 PM
Importracer
Nov 26, 2001 10:39 PM
