Headlight/hid question 04-05
Old Oct 4, 2007
Honda2k4's Avatar
Honda2k4 is an unknown quantity at this point
Is it possible to have hids in the spot where your hi/low bulbs are? the inner bulbs on 04-05s.
If its possible I would be using those lights during the night, also wondering if there would be enough light coming through to see properly.
Old Oct 5, 2007
electric130's Avatar
Re: Headlight/hid question 04-05
no you can't run HID's in the place of your high beams and still use them as DRL's. the HID's have to have full voltage in order to work. trying to run them like DRL's will likely damage the ballasts. that's why cars like Acura TL's that have bi-xenons (only one HID headlight) have a seperate halogen bulb for DRL's. if you want to replace your high beams with HID's, then you'll have to disable the DRL function.
robjcivic
Mar 12, 2017 12:10 PM
JMKendrick
Sep 16, 2015 06:17 PM
AyyeeGeorgee
Sep 14, 2015 12:54 PM
junkyardguy
Sep 2, 2015 06:07 PM
h4ldol
19
Jul 28, 2015 01:01 AM
