HID install help plz.
I just bougth a H4 HID kits and the low beam lights didn't work , only works for high beam lights. When I put that into the corolla 98 with the same kits, it works nicely. My car is Acura EL 1.7 ,what can I do or need actually for installing HID.. relay, fuse... ? Can anyone help me with this and sent me a good instruction because I am so new about that and stupid.. haaa.. thx..
This is the information of my ballast ...
input voltage :9-16V
Normal voltage :12V
Max input current:10A
Rated current:3.5A
Output wattage:35W
Starting voltage:23kV
THanks for help
sent me email if have a fully detail of instruction. foureyeman@hotmail.com
Normal voltage :12V
Rated current:3.5A
Output wattage:35W
THanks for help
your gonna need a relay wire and connect it to the battery, they sell them at www.hid-lights.com and click on accessories. Get the relay set for H4. your gonna have to splice wires and connect them. My brother had the same problem with is H4 Hids and had to buy a set of relay wires.
Im not sure whether these connectors are compatibile with your connectors though. The ones they sell here ARE NOT the universal amp connectors. Amp connctors are the universal ones. If they are amp connectors you can find the relays on ebay. Amp connectors look like this.
I have the relay kit from my old HID set. but it still didn't work when i connect the relay kit to my new HID kit.
however one thing i found out is that... the Max current input for my new HID ballast is 10A.. my old set is 20A. that's the only difference between my two kits.. the old kit worked on my car.
so can i say that my car is putting too much current to my new kit so that it didn't work.. coz i found out the fuse for the car's headlight is 15A.
The World Is Yours!
well i know when i had installed my hids, i had to play with the metal prongs to find out which was placed where. one is for the highs and one for the lows. as you see in the pics, it has three, a standard low beam hid has only two. if this makes sense.
i am again having the same problem my low beams dont work at all, but i have 2001, when i used to another hid kit, and the i found out that on the 01s the wiring has be reversed or somthing lk that which doesnt make much sense but yeah, i need help on this one again!! it wont lite up :S?
mjdiaz89
Jun 21, 2016 09:26 PM
OptimisticWay
46
Oct 15, 2015 02:16 PM
17
Jul 23, 2015 11:48 PM
EM_WON
Jul 22, 2015 06:49 PM
