Basic LED hookups
Basic LED hookups
Hope this helps some of you wanting to learn more about wiring leds. its different than bulbs, they must be polarized and they must have resistors in most cases. the specs for each color led are different, and you need to know these values to calculate the proper resistor. it will also vary depending on how many leds you connect together. they can be wired in series, however there is a limit to this, usually only 3-4 leds is possible. so if you want more, you need to make many series and then hook each one up in parallel. this is so they retain brightness. use this link to calculate the resistor and then goto radioshack and buy it. if they dont have the exact one you need, always choose the next highest resistor. Also remember you can add resistors together! if you need 300ohm resistance and they dont have it, you can buy a 200ohm and 100ohm and hook them together.
LED Series Resistor Calculator
I bought two 3.7V 20mA blue LEDs from radioshack. The calculator states I need a 360 Ohms resistor but then I wire it up to a 12V it is less brighter than a 100 Ohms resistor. Does (14.4V - 12V= 2.4V) make that much of a difference?
yes it does. hook it to the car battery with the car running and it will be noticably brighter. when i hooked up an extra led to push total required voltage to 18v, they hardly lit up at all.
Using the proper resistor value for LEDs is important to get the voltage in the right range. Some LEDs can handle slightly higher voltage and will light up more brightly but you run the risk of the LED burning out prematurely.
Personally, I like metal film ressistors over the carbon film as they have a closer tolerance and better heat disapation. If you have trouble finding ressistores, visit mcminone.com. They carry a huge assortment. Shipping cost are a dealbreaker unles you order several ressistors at once. I think it cost me the same to ship 1 ressistor as it did for 30 of them.
Originally Posted by 7thGenerasianCivic
do i really need a 360Ohms resistor for a 3.7V 20mA LED coming from a parking light? It just seems to me like an overkill... haha
How did you get 560 ohms Steve? I used the calc and it gave me 390 ohms.
2 LEDs, 3.7V, 20mA, 15 total V
this is so hard to understand!! ahhhhhhh
Last edited by 7thGenerasianCivic; Sep 21, 2006 at 01:52 AM. Reason: Automerged Doublepost
in your first post you said A led not TWO lol, and went on to say for a single parking light, which i assume is only one bulb. thats different so the 390 would be correct for two leds wired in series
frank_kleng
Sep 29, 2015 10:55 PM
MamaBear2015
Sep 24, 2015 11:34 AM
Klame9420
Sep 18, 2015 12:37 PM
