04-05 headlight aim adjustment
Proudly Canadian
Alright I read the DIY posted on here but I still can't find these gears or screws that people are referring to. I see the symbol for U/D and L/R adjustment, but where the hell are the adjustment screws?? The holes are just thru to nothing, no gears under them..
R-L DRIVERS SIDE
U-D DRIVERS SIDE
U-D PASSENGER SIDE
L-R PASSENGER SIDE
PASSENGER SIDE GENERAL
R-L DRIVERS SIDE
U-D DRIVERS SIDE
U-D PASSENGER SIDE
L-R PASSENGER SIDE
yea its been covered a bunch of times but o well. if u look behind the headlights there is a silver bolt/screw lookin thing, that is yer adjuster. for the driver side u might need to take off the power steering reservoir(sp?) which just slides right off of the mount. the pass side just unbolt the battery tie down move the battery a bit and u can get to that one too.
dont look at that DIY.... if u look from the side and behind the headlight.... u will see a grey bolt with teeth.... and u just turn it.... i read that DIY and couldnt find it either... u need a like 9inch screw driver to do it
Bricoleur
Sep 9, 2015 12:23 PM
04, 06, 2002, 2003, 2005, adjustment, adjustments, aiming, ajustment, civic, headlight, headlights, honda, pictures, si
