successfully wired ebay fogs? *update* fogs installed with pics no 56k
Has anyone successfully wired ebay fogs using the wire harnesses w/o any modification to the wires?
I just bought a pair of fog lights from ebay and the wiring is pretty messed up. I thought it was going to be straight forward but I was wrong. Im thinking of using the relay and the inline fuse from the harnesses and doing my own wiring.
I know for sure that the wiring from the fog lights just past the firewall is fine. I directly connected the lights to the battery and they worked. Its just the part of the wiring from the inside thats confusing and not making sense to me.
I'm unusually bored.
Yeah I understand your problem... my solution involved omitting the switch, and wiring it to come on whenever my lights or parking lights come on. I ran my own power wire to the inline fuse that goes the relay, and used the 4 prong connector with the wire coming out of the far right that seems to lead nowhere in the fuse box as the switch wire. You can ground it to whatever ground point you want to as long as everything is actually grounded. I know this may be confusing, I'm headed out now, but PM me if you have questions.
lol i know exactly wat ur talking about. that crap dont fit together correctly. i couldnt do it, so i ripped the switch harness out and chucked it as far as i can and ghettofabbed it.
Definitely common unleaded....
tony_buttons...I might be PMing u here soon when I have time to mess with the lights and I know what u mean about the wire that leads to no where...I was like wtf?!
eugthebear...im pretty much going to be doing the same...its basically useless trying to make do with what they give u..lol
You can run the relay off of the headlights, so when they turn on the fogs get power. This method doesn't draw any power off of the headlights themselves, as the power coming from them simply tells the relay to open and switches on the power straight from the battery. I have mine rigged up like this for a while now.
I have the same story, im looking for some help aswell, check out my thread http://www.7thgencivic.com/forums/sh...d.php?t=255593
are yours like that? i think the problem is that we bought 2001 kits off ebay and the 2003 civic harness is different
I just burnt my tongue
mine were direct plug and play...no modification needed worked from the beggining...i just changed the cheap inline fuse to a higher quality fuse of the same amperage rating...and done and done no problems here
Interior - Parking lights on fogs off
http://i6.photobucket.com/albums/y20...1/IMG_1199.jpg
Interior - Parking and fogs on
http://i6.photobucket.com/albums/y20...1/IMG_1200.jpg
http://i6.photobucket.com/albums/y20...1/IMG_1202.jpg
http://i6.photobucket.com/albums/y20...1/IMG_1206.jpg
I have a red switch now just need to put it in and I plan on getting some yellow nokya bulbs
Last edited by infinite012; Apr 12, 2006 at 07:31 AM. Reason: Automerged Doublepost
mistermenphis22
Apr 3, 2016 08:06 AM
nickeynick
Apr 27, 2015 01:23 PM
