Neon light question
Old Mar 30, 2006
CrazyKnight's Avatar
CrazyKnight is an unknown quantity at this point
Neon light question
Ok i have some neons that i want to hook up on the inside of my car and i know where i want to put them and how to mount them thats the easy part. The thing im wondering is the ones i got are the ones that you would plug into your cigerette lighter and thats how they get power. But i want to hook them up to a switch so i can turn them on and off when i want to with out unplugging them. What im thinking is cut the cigerette lighter thing off and them one of those two wires is power and the other is ground am i right? so in turn all i would have to do is hook up the power one to my batter then a switch and then the light and then the ground would go from switch to light to a grounding location am i right or is there a different way to do it? Or is there just neons out there made like that that i can buy that arnt to much money. I have a 2005 civic vp i dont think it matters the car but if it helps. thanks alot guys and gals.
Old Mar 30, 2006
diskreet's Avatar
1. Yes the wires should be power. CCFL tubes (what you have) run on AC power, but most of the time the AC converter (from the DC the car powers at) is IN the base of the tube.
2. Just splice the wires with the cig. lighter plug wires behind the panel the cig lighter is on.
3. Put a switch on either wire, + or -. Done.
or
1. Don't do it cause neons usually look tacky and ricey.
Either way, I hope I helped.
Old Mar 30, 2006
eddiechaps's Avatar
i love my morreale
put some leds in a group & stick them where no one can see them, but give off an ominous glow.
Old Mar 30, 2006
i just put neon under seat and wired to cig lighter so they're on all the time. looks good to me, soft glow.
Old Mar 30, 2006
notoriouspyro's Avatar
Crack kills... But then again... So do I...
notoriouspyro is a jewel in the roughnotoriouspyro is a jewel in the roughnotoriouspyro is a jewel in the roughnotoriouspyro is a jewel in the rough
^^^ That's what I did too... Don't have any pix right now or I'd show you. Yeah it's really simple to run the neons to a direct line. What I did is mounted a switch in the center console attached to an inline fuse that connects my 4 neon tubes. Been working fine for the last yr and a half.
Old Mar 31, 2006
Well thanks for the helps guys. I hooked them up to a switch yesterday and it works great i only have one for now but soon like today or tomorrow i will have probably another atleast. Ill take a pic today of what it looks like.
Old Apr 2, 2006
BrynDN's Avatar
BrynDN should not be trusted
I did the same thing with two ultra bright red LED's at the top of each kick panel. Gives a similar light glow, and it's impossible to see the LED's. This was cheaper than neons, but required soldering resistors into the power wires as well.
I'm glad to hear that you got your setup working though. Post some pics.
Old Apr 8, 2006
soccer1cb's Avatar
soccer1cb is an unknown quantity at this point
Sorry to bring this thread back to life but, I would be interested in seeing how much light that LED you installed is putting off, in comparison to the neon...a pic would be great....thanks
Old Apr 10, 2006
gh0st's Avatar
TAQUITOS!!!!
depends on what LED you get...superflux LED's are stupid ridiculous bright. typical LED's are nice and bright when powered correctly...
gearbox
Electrical DIY
72
Nov 27, 2015 08:13 PM
NukeSilo
Nov 20, 2001 05:17 PM
klam
Nov 16, 2001 03:36 PM
viper775
Nov 15, 2001 10:54 PM
NukeSilo
Nov 4, 2001 09:37 PM
