need some help guys........F***en projectors
Old Mar 27, 2006
Mr. Fantastic's Avatar
Mr. Fantastic is an unknown quantity at this point
04 civic sedan......., all right, so last night i realized that my low beam went out on my halo projectors( courtesy of ebay, the ones with the black housing). I thought it was my bulb, so this morning i replaced it, and it still does not work. The high beam and turn signal work perfect. Ive had these projectors for over 4 months maybe more. The left headlight is perfect, this is only on the driver side headlight. I checked the adapter and the harness and evrything looks good, any ideas???????
p.s. yes i did try the search button
Old Mar 28, 2006
jay78's Avatar
jay78 is on a distinguished road
so bulb is ok not blown right?
then try to connect stright to the 12v and see if it works
check all the fuses the one under the hood....passenger side....
Old Mar 29, 2006
ya check the wires. i'm gonna say its a bad ground at the projector. plug in the bulb outside of the projector and then touch the metal housing of the bulb to a chassis ground. if it lights up, bad ground.
Old Mar 31, 2006
ok, so turns out i was wiggling the connector and it turned on, then let go and turned off, and back and forth. I managed to manipulate the connector (where they plug in) to rest on the power steering tank, and it seems to work as long as it stays in that position. hm.......
wingsfan19
Oct 1, 2015 03:45 AM
carid
Jun 5, 2015 11:51 PM
Exbauer
Apr 3, 2002 01:04 AM
AzNmiKex215
Mar 30, 2002 10:08 PM
Diznavis
Feb 19, 2002 12:41 PM
