Tapping into Dome light???
Old Feb 20, 2006
02white4dr's Avatar
02white4dr is an unknown quantity at this point
Where would you guys advise me to tapp into my dome light wires? Does anybody know what side the run down?
Old Feb 20, 2006
you have to tap directly into the dome light bulb wires, and i mean the ones an inch away from the bulb. i tried tapping ALL the wires running in the driver side pillar and none of them worked like the dome light did with the fadeout and stuff. trust me i've tried it when wiring up the marker lights. had to run wires up through the pillar and in the roof liner to the center bulb. you can access the wires by removing the two screws holding the assembly.
Old Feb 21, 2006
02white4dr's Avatar
damn... cause i just wanted to put some lights under the dash and have them go with the dome light. I may have to wait until saturday to do this then
Old Feb 21, 2006
CraigW's Avatar
There is a low current source at the connections for the key cylinder. (used to illuminate the key cylinder on EX models) It would come on and go off with the operation of the doors, independent of dome light.
Old Feb 21, 2006
but i wouldn't wire bulbs to that or neons even. leds maybe.
Old Feb 21, 2006
CraigW's Avatar
The location is Pin 5 = Wht/Blk Pin 6 = Wht/Blu on the connector for ignition switch.
I would not tie any heavy or strange (transformer/inverter) loads into either the dome circuit or the key cylinder illumination circuit. It would be easy to damage circuit.
Old Feb 21, 2006
02white4dr's Avatar
I was goiing to put some blue Neons or leds under the dash and hoook them to the dome lights. is this a bad idea?
Old Feb 21, 2006
Cptn. Slow's Avatar
Formerly efil on evol on
Cptn. Slow has a spectacular aura aboutCptn. Slow has a spectacular aura aboutCptn. Slow has a spectacular aura about
dome lights are fine and it is not that hard
Old Feb 21, 2006
uh you realize that anything connected to the domelight will only work when the domelight is on? i dont see the point of ocnnecting anything to it unless its marker lights of something. i have 2 other bulbs attached to the wiring so it should be fine. thats 15w its drawing and no problems.
Old Feb 22, 2006
hojo35's Avatar
hojo35 is an unknown quantity at this point
I hard wired my radar detecter in this way I took the center metal piece out and found the hot wire where there is continuous power all the time without the dome light being on . Have not had any problems and its clean there is only about 3inchs of wire hanging down and you dont see it with the mirror.
Old May 16, 2006
blk04civiclx's Avatar
blk04civiclx is an unknown quantity at this point
Is there any way i can hard wire my Ipod to a hot wire like you were saying ^^ sick of pluggin it in the socket all the time..
Old May 16, 2006
there's always the 12v socket plug wire. just pull the piece off and look behind. there are two wires going to it, power and ground. tap those, and it will turn on everytime the car is in ACC position (or turned on too).
Old May 16, 2006
u kno how the ipod charger.. its only one cord.. how would i do it? I would supposed i would have to cut off the adapter part that connects to the socket and strip it?
Old May 16, 2006
well it plugs to the socket right? there has to be two wires, power and ground. i'm not sure which is which but ya. cut off the socket and strip wires or tap to wires behind socket.
Old May 16, 2006
CraigW's Avatar
I would make sure first it is not somehow reducing the voltage inside of the adaptor. (it may not be the full +12 volts fed into the Ipod)
For a constant +12 source I tapped into the memory lead at the head-unit. A lot of work to get that thing in and out though.
Lopes101
Jun 7, 2015 08:04 PM
beveragemp
May 25, 2015 07:11 PM
twtron
Apr 17, 2015 12:09 AM
meels808
Nov 5, 2001 09:15 AM
TropiKalCiviC
Sep 25, 2001 07:02 PM
