For all of you that have installed HID lense into TYC..
Old 03-13-2006
  #31
82801BA's Avatar
82801BA is an unknown quantity at this point
I've never seen a 4100K bulb that is "white" though.....Not even the 4100K silverstar...That is still pretty much yellow (I would say a whiter yellow)...Anyway, in a distance I don't see reflected "yellow" light. I am away from home and no computer here can take my CF so I can't send any picture...
As a side note......
The "white balance" significantly change the light temperature spectrum. There are several scales that does it. You may have a 4100K light with 3200K white balance, the light is yellow; or 5500K balance to have a white light, or even 7500K balance to see blue from 4100K. Look at your monitor (if it has that function) you know what I am talking about....
Old 03-16-2006
  #32
82801BA's Avatar
Just back home from Houston and first time driving on highway at night.....
It looks like my new retrofit has some glare problem...
First, I realize that the car in front of my left/right side cases a shadow on the side freeway signs....
Second, when I pass under freeway signs (those high overhead signs), I completely illuminated those.....
Is there something wrong in here?
Old 03-16-2006
  #33
82801BA's Avatar
Here's the beam pattern and the looking at the beam......I am thinking it's the chrome reflector at the bottom that casts the glare.....Any idea?
Name:	IMG_0053 (Medium).JPG
ID:	65115   Click image for larger version
Name:	IMG_0057 (Medium).JPG
Old 03-16-2006
  #34
the wall shot looks good. and yes you are right. that was the same reason the chrome tyc stayed in production longer. they had to solve the glare problem from the chrome housing. they brushed it to fix the halogen problem but yours is making it happen again. you should think or a way to fix it, maybe by painting it chrome (silver) which will be less reflective.
Old 03-16-2006
  #35
82801BA's Avatar
I would go ahead and do the blackout at the bottom.....Just want to find a way that it can be blacked out without having to remove the assembly again....It's going to be a headache to remove it....I just want to have the glare gone....May be I should try inserting a tube in there from the parking light opening and squeeze paint to the bottom?
Old 03-16-2006
  #36
um no lol
Old 03-16-2006
  #37
82801BA's Avatar
So have to take apart the headlight again?.
Old 03-16-2006
  #38
ya i don't think there's any other way.
Old 03-16-2006
  #39
82801BA's Avatar
Man, I don't really know if that's really glare or anything....I don't light up the car in front of and diagonal to my car, not even the license plate (except the reflective surface on a cop car, of course)...It's just the signs are bright....I have no idea, very confused...
Old 03-16-2006
  #40
well when you look at the lights above the cutoff, do you see any glare? you should hardly see anything shining at you
Old 03-16-2006
  #41
82801BA's Avatar
I don't see too many things above the cutoff....Just some roadside reflective markers and orange signs that are bright....But I can see those signs and markers 1/2 miles before I reach them....The cut off (VOR) on a leveled ground is about 5.5 cars and the higher side is about 6.5 cars....Then I don't see many things on the ground up except signs and some "blue reflected" road reflectors (don't know what's that called) which are not very bright either.....
Old 03-16-2006
  #42
hmm okay on mine I can sometimes see the blue cutoff reflecting off signs. i know mine are aimed low too. but there needs to be some glare or you won't be able to see any signs (above the cutoff).
Old 03-16-2006
  #43
82801BA's Avatar
So you think I should be fine with it? I drove for 3 hours yesterday and never got a single flash, nor any cars that doesn't like to be straight in front of and diagonally in front of me?? By that I mean ppl can still stay diagonally or straight in front of me for several minutes without doing anything weird....
Old 03-16-2006
  #44
what happens when you drive up to things, like glass windows, white fences, etc. is there alot of weird stuff above the cutoff? or nothing?
Old 03-16-2006
  #45
82801BA's Avatar
Basically none....Above cutoff there's almost completely dark from side to side.....It's just when I see the road signs it scares me....I don't know if my pic shows anything, but that's the pattern I took at about 30 feet on the driveway from the wall with car front higher at an angle....
Old 03-16-2006
  #46
hmm i would say you're fine then. i mean usually you'll get some flashes from people if its glaring.
Old 03-16-2006
  #47
82801BA's Avatar
So is it just some signs that are "super reflective" compared to others? Cuz I don't see all signs that are illuminated, but some are super bright....Same sign level on a leveled road, of course...
Old 03-17-2006
  #48
well i can't see any road sign with mine at all. maybe they're aimed too low. or just not bright enough.
Old 04-10-2006
  #49
82801BA's Avatar
Infinite, do you see ANY problem with it? The road is slightly inclined....
Name:	IMG_0064 (Medium).JPG
Old 04-10-2006
  #50
TAQUITOS!!!!
gh0st's Avatar
wall shot from 20 ft would probably be better.
from what i see, that looks about the same as mine.
Old 04-10-2006
  #51
ya that looks pretty good
Old 04-10-2006
  #52
I log in from time to time
dirtySAMURAI's Avatar
cant really tell from that picture, but it looks good.
Old 04-10-2006
  #53
82801BA's Avatar
Should have wall shot tonight...
Old 04-12-2006
  #54
82801BA's Avatar
Finally......
Old 04-12-2006
  #55
looks good to me
Old 04-12-2006
  #56
ya thats great, and as you get closer you should see the cutoffs start to separate. tons of color in there too.
Old 04-12-2006
  #57
7thGenerasianCivic's Avatar
Looks good
Old 04-19-2006
  #58
82801BA's Avatar
What will happen if I swap the X1010 bulb (5400K Discharge High-Color) into the projector? Just whiter?
Old 04-19-2006
  #59
Hmm... X1010 huh?...
It will be the same concept: higher temp lower lumens. The only difference is that the X1010 uses D1S bulbs.
Old 04-19-2006
  #60
82801BA's Avatar
I don't think D1S and D2S bulb has any difference (with respect to fitment?) The D-HC bulb are rated at 2600lm so I think it is still a lot better than stock helogen isn't it? Just wonder if cop will stop me if I am having the 5400K in there...Sylvania claims that 5400K is the highest color that's legal??
Quick Reply: For all of you that have installed HID lense into TYC..
