foglights..
foglights..
okay,,, sooo i think i'm gonna have honda install them cuuzzz i suck at doin **** myself.. and if they install them, they wont wrap the lamps with the yellow sheets so thats not an option.. my question is.. is it still worth getting yellow bulbs or shuld i just get white ones. i really wanted yellow, but im not sure if it will be bright enough w/o the protective sheets on..
you can put the yellow protective sheeting on yourself. it's not hard. just cut it and stick it on. i don't see what the big deal is?
not at all. just hold the sheet up to the foglights, trace an outline, give the outline another 1/4" of cushion, then cut the larger diameter outline. stick the sheet on to the foglights and you're done. again, not hard at all.
i had the dealer install mine (read: 1 kidney paid). but as far as putting the protectice lamin-x or whatever brand, you can always take off the foglights and refer to here:
http://www.7thgencivic.com/forums/sh...d.php?t=197751
good luck and enjoy
good luck and enjoy
ferio
Oct 20, 2003 08:51 AM
