04-05 Projectors
Old Jan 23, 2006
SEVYN's Avatar
SEVYN is an unknown quantity at this point
04-05 Projectors
hey buddies.
i want to get projectors for my HIDS, but
i saw a thread on here about a guy doing a retrofit on his lights using the 04-05's projector lens.. then i saw a thread taht said that these crappy projectors couldn't handle the heat from the HIDS.
so in the end, is it possible to or no?
Old Jan 23, 2006
SEVYN's Avatar
bump bump!
Old Jan 23, 2006
R1Style's Avatar
Yes it's possible... get a decent set of projectors. You're also going to need new bulbs.
Get ready to do a LOT of custom work.
Check out the discussion forum on http://www.hidplanet.com/main.html You'll see a lot of retro fits on there.
btw... HID's run cooler then standard halogen bulbs.
Old Jan 23, 2006
mikenam's Avatar
mikenam is an unknown quantity at this point
y don't you retrofit hid projectors. made for hid. Valeos, tsx, s2000.......
Old Jan 23, 2006
ragingSPAM's Avatar
I just burnt my tongue
well in the 04 05s i know that the s2000 wont fit (in the aftermarket projectors) cuz my friend tried them and they were too large at the bowl even tho the lense wasnt that big
Old Jan 23, 2006
dtox666's Avatar
dtox666 is an unknown quantity at this point
If HIDs are more efficient and use lower wattage wouldn't they produce much less heat than halogens...?
Old Jan 23, 2006
TemjinX2's Avatar
real hid projectors should be able to handle them fine. I have fiberglass shrouds around my projectors and there fine. The HIDS probably give off less heat since they use less wattage then halogens.
Just click on the link on my sig if you wanna take a look at my retro project.
Old Jan 23, 2006
dirtySAMURAI's Avatar
I log in from time to time
in an HID capsule, the salts burn at ~450F (i think), so it gets hot, but it doesn't spread heat the same way that the halogen bulb spreads heat.
Old Jan 23, 2006
Kimira's Avatar
Kimira is an unknown quantity at this point
damn... I wanna try to fit in a tsx HID projector in, does any one know how to do that or point me in the direction? thx.
Old Jan 23, 2006
unknown01civic's Avatar
unknown01civic is an unknown quantity at this point
i have tyc projectors they have H1 bulbs what would the best hid kit if i really like my tyc's
Old Jan 23, 2006
worst question ever. the best kit is no kit.
Old Jan 23, 2006
find some tsx projectors, some sheet metal, nuts, bolts, a dremel tool, and a lot of time. you might need some bandaids, too.
Old Jan 24, 2006
R1Style's Avatar
Originally Posted by R1Style
I posted this above... this company sells aftermarket HID specific projectors. You can retro fit these into you TYC's or OEM headlights.
Old Jan 24, 2006
they're actually all OE...in other words, the products that hidplanet sells are available in mass produced vehicles in the united states and even from the UK
wingsfan19
Oct 1, 2015 03:45 AM
AyyeeGeorgee
Sep 14, 2015 12:54 PM
h4ldol
19
Jul 28, 2015 01:01 AM
carid
Jun 5, 2015 11:51 PM
Exbauer
Apr 3, 2002 01:04 AM
