Strange- headlights went out together tonight
Old Dec 6, 2005
StealthCivic's Avatar
StealthCivic is an unknown quantity at this point
Suddenly both my headlights went out tonight, the parking lights still worked, but both headlights were off, I checked fuses , they were fine, then I toggled and pushed on the connectors to the bulbs and the wires in that area, miracously as I pushed on it one came on, then I did the same and the other light came on..................don't understand this, or what caused it........
Old Dec 7, 2005
dirtySAMURAI's Avatar
I log in from time to time
maybe it was vibrations? or a ghost..
Old Dec 7, 2005
jay78's Avatar
jay78 is on a distinguished road
put some electric tape around...
Old Dec 7, 2005
4rns860's Avatar
4rns860 is an unknown quantity at this point
That Happened to my civic also the lights just went out I tested all the connections under the hood and the fuses and even replaced the bulb itself until I took it to a mechanic and he mentioned that my ground wires burned out..
Old Dec 7, 2005
Hey thanks, yall, I checked them out and put back in some cool blues like I used to have...they worked...my bulbs were burn out - phillips blue....burn out, I like the cool blues bulbs better, I put them in...problem- my rubber weather seals are gone, both of them! I need some new rubber weather seals around my bulbs so the moist/weather doesn't mess up my bulbs and burn them out...where can I get these seals I don't know where they went!!!!
Old Dec 7, 2005
yup it had to be the moisture that can quickly kill a bulb.
Old Dec 12, 2005
ser02rav4's Avatar
ser02rav4 is an unknown quantity at this point
advice - change your bulbs. Hope it will help!
Old Jan 3, 2006
digitaldemigod's Avatar
2001 Rallye Red EX
digitaldemigod is a glorious beacon of lightdigitaldemigod is a glorious beacon of lightdigitaldemigod is a glorious beacon of lightdigitaldemigod is a glorious beacon of lightdigitaldemigod is a glorious beacon of lightdigitaldemigod is a glorious beacon of light
This happened on my 96 hx about 3 months ago. I did not believe that both headlights could possibly burn out... and since my wiper switch had gone out and been replaced, I bought a new light switch and replaced that... only to find that it was not the problem. Both lights needed to be replaced.
Old Jan 3, 2006
ragingSPAM's Avatar
I just burnt my tongue
actually the 2002 civic's had a recall if i remember correctly about the lights just disconnecting and turning off randomly "which can cause accident or injury"
Old Feb 2, 2006
justright's Avatar
justright is an unknown quantity at this point
Headlights off
Today I came out of the store and only my high beams work. I cannot figure out what happened. What is the problem....expensive to fix.
Old Feb 7, 2006
jdm_es2's Avatar
jdm_es2 is an unknown quantity at this point
maybe you should contact your local dealer to see what they have to say
MamaBear2015
Sep 24, 2015 11:34 AM
shaejb15
Sep 12, 2015 01:02 AM
Bricoleur
Sep 9, 2015 12:23 PM
thaler4cuse
Sep 7, 2015 08:25 PM
MamaBear2015
Sep 4, 2015 09:04 PM
