Need help w/Dash lights problem.
Old Dec 1, 2005
EManEX's Avatar
EManEX will become famous soon enoughEManEX will become famous soon enough
Last night I go to turn my car on and as I'm driving away I notice that half of my speedometor is not lighting up. I can't read the gas level and the speedometor neddle doesn't light up.
Any suggestions on how can I fix the problem?
Thanks
BTW: The car is a 01 EX. Auto.
Old Dec 3, 2005
EManEX's Avatar
If you guys need more info, just ask. If you guys don't know what is going on I guess I'll just let this post die.
Thanks again.
Old Dec 3, 2005
its just a bulb that burned out. take the cluster out and twist off the bulb from the back. There are five total in an up/down pattern. You can post a pic and I'll see if I have a spare bulb. 01 and 02 use different bulbs btw.
Old Dec 3, 2005
EManEX's Avatar
Thanks man, I thought that they used LEDs. Good to know that they are just bulbs. Is there a DIY for taking the cluster out? I'll seach for it.
Once again thank you.
Old Dec 3, 2005
well its easy. there are two top screws, then you take the black trim off. then three more screws and the cluster comes out. you can unplug the connectors if you want. 01-02 civics use bulbs, 03-05 use leds.
97-DX-Lover
Jun 14, 2015 06:07 PM
Black91civic
Jun 6, 2015 08:15 AM
jakeconnor
May 5, 2015 07:30 AM
dooner24
Apr 14, 2015 07:51 PM
Hondasport01
Dec 17, 2001 01:53 PM
