led lights
led lights
i want to upgrade to led lights. license plate/tails/break/reverse/blinker/dome all lights all over my car. where can i buy. what sizes do i need. also it is just plug and play install correct.. please help.
A big, hairy Kentucky boy
I wouldn't recommend switching to LED on anything. The light output isn't nearly bright enough. I did switch my dome lights to "super white" leds, I've lost some of the brightness, but it gives off a nice effect.
do it like this guy did from hidplanet.com
http://pictures.dirtysamurai.com/daveShowsOff.avi
http://pictures.dirtysamurai.com/daveShowsOff2.avi
http://pictures.dirtysamurai.com/int...djustments.avi
http://pictures.dirtysamurai.com/led_demo.wmv
http://pictures.dirtysamurai.com/tail_light_demo3.wmv
link to thread:
http://www.hidplanet.com/forums/view...er=asc&start=0
link to thread:
Electric Boogaloo...
LEDs in your turn signal will not yield the same brightness as the incandescant bulbs. well exterior that is. and that's just unsafe. i've tried it in the the brake light and the front turn signal...it's simply not worth it.
as for the map/dome lights on the inside...i have some LED plug n play bulbs and they're pretty damn bright at night...don't spread the light like the stock lights, but who cares?
Originally Posted by Blackpearl
Some of the car circuits get feetback from the incandescent bulbs. I am not sure which one. If you replace them, you can end up with some malfunctions because the LED consume less power.
MamaBear2015
May 27, 2015 12:04 PM
eorlando1
May 17, 2015 11:16 AM
