HID problem
Old Oct 1, 2005
i5r's Avatar
i5r
i5r is an unknown quantity at this point
HID problem
I bought some HIDS and i tried to install them install was sucessful but the thing is only high beam works i think i gotta replace the curcuit thing in my car with a higher fuse or somthing somthing more than 20, any other suggestions?
Old Oct 1, 2005
LiKEaFeRiO's Avatar
If your kit is a low beam only kit, then you wired it up to the high beam positive most likely.
Old Oct 1, 2005
i5r's Avatar
i5r
its high low dlr
Old Oct 1, 2005
dirtySAMURAI's Avatar
I log in from time to time
you probably blew your fuse(s) for the low beam. try using a proper wiring harness that draws power directly from the battery as opposed to the stock wiring.
Old Oct 1, 2005
i5r's Avatar
i5r
brief recap from the time i bought it, i install them at night thought it would be a easier job lol but nah only the high beam goes on, so this morning i bought the 30A fuse but then it wont work still ERRR i changed both the fuse in the car and outside under the hood just to be sure, sitll not working thefore i just put my stock balbs back in and they work fine, i dont think its the fuse, and the guy i bought them from took them out of his car and then put them onto mine
Old Oct 2, 2005
platano37's Avatar
platano37 is an unknown quantity at this point
low beam problem
i had the same issue. My problem ended up being that the low beam wire was fried all the way to the termination point inside the car under the steering wheel. I ran a new 14 gauge wire directly from that point under the steering wheel straight to the low beam wire on the headlight. That seemed to work great.
I went to my local discount store and bought:
- 14 gauge wire about 20 feet just in case. ~$4
- circuit tester to test how far the break is (ended up being all the way through) ~$12
- pack of wire splice ( 7 in a box ) they are the best you put both wires in and crimp them nothing else needed. Electrical tape is recomended over it. ~$4
All was done after that. The hardest thing is to find out how far the wire is fried. You can also test to see if all is well at the termination point at the connector under the sterring wheel. If that is good you can just run a wire straight from there as i did. I think it is best becuase the heavier gauge wire helps best.
ON MINE IT WAS THE RED/BLUE WIRE. YOU WILL HAVE TO TRACE THE WIRE TO FIND OUT. ( THAT IS FROM THE HEADLIGHT CONNECTOR ALL THE WAY THRU TO THE INSIDE OF THE CAR)
ON MINE IT WAS A RED/GREAY ON THE HEADLIGHT THEN IT CHANGE TO RED/GREEN ON THE HARNESS THEN ON THE CONNECTOR INSIDE THE CARE IT TURNED TO RED/BLUE. IT WILL TAKE 2 HRS TOPS. TO TRACE AND SPLICE.
IF YOU NEED MORE HELP I CAN POST PICS.
GOOD LUCK!!
Old Oct 2, 2005
crazyimport's Avatar
crazyimport is an unknown quantity at this point
his wiring is not fried. his stock halogen bulbs still work.
the high beams work fine on the kit.. but low beams(hids) do not work.
they came out of my car which was an EK ... and everything worked fine.
its an h4 kit. and 7th gens use h4 bulbs as well.
Old Oct 4, 2005
i5r's Avatar
i5r
got MY HIDS FIXED !!!!!!! WAAAAAAAAT! i turned the positive and negative around and then WABOOM! they work! dont have DLR though :S
Old Oct 4, 2005
you mean DRL - daytime running lights
Old Oct 5, 2005
hdave's Avatar
hdave is an unknown quantity at this point
i dont know why your DRLs dont work.
you have a hi lo kit so everyhting should work fine.
Old Oct 5, 2005
i5r's Avatar
i5r
haha i just started my car today and i was driving around and i found out that i have DRLs i tihnk its just cuz i had my hand brake on HAHAHA
Old Oct 7, 2005
hdave's Avatar
lol.
how's the hid's looking?
Rogelio Rey
May 24, 2015 08:30 PM
terry_tr6
HIDs and Retrofitting
May 16, 2015 08:37 AM
Professional
Jan 6, 2002 08:27 PM
0100010
Jan 6, 2002 12:54 AM
