Mounting EL Wire
Old Sep 10, 2005
brandenw's Avatar
brandenw is an unknown quantity at this point
Mounting EL Wire
I wish i would of thought bout this before i did the install... but i just put some EL wire along the rear seat, it looks great but it wont stay in place.
Heres the problem:
I want to attach the EL Wire but i dont want to make it permanent.. Styles change... so does anyone know a way i can attach it without making it permanent?
its along the bottom of the bench where the seat meets the carpet and then runs up along the sides. i just did an outline of the whole bench.
Any Ideas would be great.
Old Sep 10, 2005
If you are sticking to plastic or metal, use 3M double sided mounting tape. It can be trimmed and hidden if the wire is visible and you don't want tape showing. Just use alcohol to wipe and clean the area first.
Old Sep 10, 2005
brandenw's Avatar
well its neither plastic nor metal. its the carpet but i will remember that tip for when i do the doorpanel.
have any ideas for carpet?
Old Sep 10, 2005
if its unimportant then use a drop of super glue. If its important, try some adhesive foam tape but it will be visible.
Old Sep 10, 2005
brandenw's Avatar
hmm adhesive foam tape might just work... ill give it a shot and if not then i will have no other choice but to use super glue
jcb111
SOHC D17Ax non-VTEC - VTEC Engine Swaps
Apr 17, 2025 12:24 AM
trellex
Jun 30, 2015 07:13 PM
MamaBear2015
Jun 11, 2015 07:33 PM
GH04si
Apr 15, 2015 08:13 PM
CaseysGuy385
Jan 21, 2002 08:44 AM
