moisture in passenger light..please help!
Old Jul 31, 2005
jeremys's Avatar
jeremys is an unknown quantity at this point
Hey everyone,
Hoping you pros can help me out with an issue I'm having.
I just nonticed the other day after washing my car that moisture has started to appear in my passenger front headlight. A day later now...and a little is still there. I have had the car for two years and it has never been an issue. Nothing has changed except I got tints the other day....(shouldn't have anything to do with it)
Anyways, does anyone know how I can fix this or when I take it into the dealer for service, is it something that can be easily fixed?
Any input would be greatly appreciated.....I love my civic and can not rest until I know the headlight is ok!
Thanks, Jeremy
(2002 Civic SIG)
Old Jul 31, 2005
take the bulb out and shoot some hot air in with a hair dryer.
Old Jul 31, 2005
jeremys's Avatar
Thanks for the quick reply! I will start by doing that....but the moisture will probably eventually return right? I am wondering if I need a new headlight assembly? Dam, that sucks if I do.....any idea what they go for?
Thanks again....Jeremy
Old Jul 31, 2005
White05EXSE's Avatar
White05EXSE is an unknown quantity at this point
maybe you could take the headlight out, oven it; 250 for 10 mins; then reseal it. that def. should work. if it doesnt, it's time for some projector headlights, my friend.
Old Jul 31, 2005
New headlight is around $250 for ONE. Yours is prolly fine. The only way it would fog is if something isn't sealed right. Either around the two halves or a bulb socket. Those aren't air tight. I live in a humid place and mine fog all the time, as does everyone elses.
Old Jul 31, 2005
KnocturnalEM2's Avatar
I am your Mom's Hero!!
I would first do as gearbox says and try the blowdryer...if the results do not suite you then take them apart clean and re-seal them with either permatex or silicone!!
Old Jul 31, 2005
jeremys's Avatar
Thanks again guys! I just did the blowdyer trick. Cleared it up after about 15 seconds. I will give that a shot and see what it does. It has been VERY humid this summer so thats probably all it is.
Really appreciate you help guys!
Jer
Old Jul 31, 2005
Al Gore FTW's Avatar
jdmtytedoridori
good stuff
Old Jul 31, 2005
zachgeyer's Avatar
heat gun
Old Jul 31, 2005
burke420's Avatar
The World Is Yours!
i, when the problem occurs, tunr my wheel, put a fan on it, then while asleep at night, let it air out with a room temperature air so it dont damage anypart of the light, and it should be dry the next day and if it's hot outside, take off a the side bulbs, and let it evaporte during the day too! to dry out the housing more.
Old Aug 11, 2005
jeremys's Avatar
well, the dam moisture is back....and it only happens in the one!! I have it being serviced tomorrow.....is this somthing I should get the dealer to look at??
Thanks again guys,
Jer
ps, I already did the blowdryer thing..worked great but I dont want to have to keep doing that everytime.
Old Aug 11, 2005
dirtySAMURAI's Avatar
I log in from time to time
are the headlights stock? or have you opened them up to clear/paint them before?
Old Aug 11, 2005
btw, moved to my forum.
Old Aug 11, 2005
jeremys's Avatar
Thats a good question, I looked closely, and it is a stock headlight, although not OEM. looks the same but different manufacturer. (not the 1st owner). I personally have never opened it up..heck I don't even no how to remove the unit. This sucks, cause I don't want to have to dry it out all the time, but also don't want to spend 250 on a new one.
Any advice or alternatives that I have? Thanks,
Jer.
Old Aug 11, 2005
get replacement headlights. i dont know where gearbox got that $250 each quote from unless you're buying it from the stealership.
www.ebay.com search for 01 headlight civic. they sell for about $50 per side plus shipping
Old Apr 10, 2011
bob99cat's Avatar
bob99cat is an unknown quantity at this point
Re: moisture in passenger light..please help!
Where can I find instructions/pictures how to take the headlight lens out? Much appreciated Samuri
Old Apr 10, 2011
2005civiclx's Avatar
2005civiclx is a jewel in the rough2005civiclx is a jewel in the rough2005civiclx is a jewel in the rough
check the date samuri is probably not even on the forums anymore and try the search function first then make a new thread if you can't find anything. I searched for you and found this real quick but next time try using the search function.
Just pry the tabs off and take a heat gun to the black tar stuff to make the glue easier to pull apart and pull off the lens.
this guy is telling how to black out lights but he explains how to take the lens off.
https://www.civicforums.com/forums/1...ixed-pics.html
SammySC
121
Apr 7, 2017 07:43 PM
lowlife9
Oct 6, 2015 04:39 PM
Wariogamer
Sep 29, 2015 09:49 AM
rovafa2002
Sep 28, 2015 06:57 PM
nixyfior
Sep 14, 2015 08:32 PM
