need wiring help (turns and parking) ASAP
Old Jul 23, 2005
sectshun8's Avatar
sectshun8 is an unknown quantity at this point
Exclamation need wiring help (turns and parking) ASAP
2003 civic lx, but anyone who knows wiring can probly help me.
1) I needed to get amber turn signal bulbs, however they do NOT make amber 7443 bulbs. Can I: A) Use a 7440 amber bulb in its place? (its the same shape and connection) Or can I B) Buy a single lead bulb connector, and splice that in where the regular 3 wire honda connector is (and if so how?)
2) The parking lights aren't working, I checked every fuse I can, bulbs are not blown.... and there is no fuse labled Parking Lights.... WTF?
Old Jul 23, 2005
dirtySAMURAI's Avatar
I log in from time to time
you can use a 7440, but it won't light up when you turn on your parking lights
parking lights not working? check every connection. maybe your harness is melted (unlikely) or cut (more likely than melted).
Old Jul 24, 2005
Another solution, send me $5 and I'll ship you my amber 7443 from japan I used for only a couple months. Very good quality and the glass is actually colored not just a coating.
Old Jul 24, 2005
sectshun8's Avatar
7440 has nothing to do with parking lights, it would be for the turn signals..... would it light up?
WAIT, why didn't you ******** tell me in the first place they DID make them, just usually cant find them at auto parts stores. They have bajillions on silve coated amber 7443's on the internet for super cheap..... damnit, lol.
And as far as the parking lights not working, is there a fuse for them like there is for the headlights and turns signals? I know they are connected to a green tab just above the fuse box under the steering wheel, but it's not a fuse, its just a plug.
Old Jul 24, 2005
CraigW's Avatar
Are your dash lights working ?? Can you here a click inside when you turn on the parking lamps ?? (tailight relay is in under dash fuse box)
I have the wiring info if you need it. PM with E-Mail address.
Old Jul 24, 2005
the parking lights have a tendency to burn out quickly due to overheating. I've seen alot of cars with one or both out. So check to make sure its not a burnt bulb first. Did you want my amber 7443? Try looking at autozone first or something cause they might have a pair.
Old Jul 24, 2005
sectshun8's Avatar
gearbox, no, I ordered a couple silver coated/amber 7443's online this morning, thanks though.
the parking lights are not burnt out. I did find out that apparently they run off a 10A fuse that also runs the tails, license plate light, dash lights etc...... all of which are out, so it's not the bulb..where the EFF is this fuse?
Old Jul 24, 2005
check the manual? Its either under the hood fuse box near the battery or under the dash where the brake pedal is. Just look up and there's a panel that comes off under the steering wheel. More fuses there.
Old Jul 24, 2005
sectshun8's Avatar
thats almost insulting, like I haven't checked the fuses. The manual doesn't list any fuse, either under the steering column or in the engine bay for the parking lights, tails etc..nor do the fuse layouts on the covers to the fuses areas list it...NOTHING. That's the problem.
Old Jul 24, 2005
sorry i assumed you didn't know where the fuse box is. I guess just take each one out. Its a pain but you'll find the one thats blown.
Old Jul 24, 2005
sectshun8's Avatar
yeah... ive checked every 10A and 7.5A one I could pull. I read somewhere that the parking lights, tails are hooked up to a green pull out connector located just above the fuses... which I can see, with a red/black wires in it, however no chance in getting to it w/o a dash tear down.... which I'm hoping I don't have to do. Am really hoping there is a more simple answer.
Old Jul 24, 2005
sectshun8's Avatar
Just an update for anyone else who has this problem, the fuse that controls the parking lights, tails, license plate, dash lights etc is the #2 15A fuse under the hood labled SMALL LIGHT. I finally fixed my problem with generous help from CraigW, thanks man!
Old Jul 25, 2005
CraigW's Avatar
Old Jul 26, 2005
ironcow's Avatar
ironcow is on a distinguished road
i just bough amber 7443s of autodynamic last week
they look great
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
clockwerx
Dec 13, 2001 12:39 PM
AzNmiKex215
Nov 29, 2001 08:02 PM
NukeSilo
Nov 20, 2001 05:17 PM
