i have sidemarkers that are always on when the lights come on
Old Jul 14, 2005
ironcow's Avatar
ironcow is on a distinguished road
how do i get it so they only blink?
its getting old and ricey having hyperwhites always on
Old Jul 14, 2005
booba5185's Avatar
7thgen Terminator Ninja
booba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to behold
it sounds like they're wired into ur parking lights, tap into you actual blinker wires, should be under the dash by the fuse box on the driver side, i dont have sidemarkers but if i did thats where i would start
Old Jul 14, 2005
dirtySAMURAI's Avatar
I log in from time to time
take the positive lead from your side marker and tap the other power wire from your turn signal.
Old Jul 19, 2005
ragingSPAM's Avatar
I just burnt my tongue
if u do that than it will only blink but it wont be on all the time...if u want it to be on all the time u have to splice a relay into the circuit and connect both the blinker, and parking light...
Old Jul 19, 2005
gh0st's Avatar
TAQUITOS!!!!
but isn't there only one power wire going into the turn signal?...and isn't it on with the parking lights since it's dual filament
(sorry, just trying to clarify for myself here too)
Old Jul 19, 2005
wow okay too much mis-information here. Sidemarkers are single filament, usually 194/168 bulbs. There are two wires coming from the sidemarker. Attach one to ground and one to the green signal wire of the front signal and they will only blink. Attach the power to the red parking light wire and they only stay on with lights. Attach one to power signal and the other to power parking light (no ground) and the sidemarker will blink AND stay on with parking light. It will flash normally with lights off, and alternately with front signal when lights on.
Old Jul 19, 2005
This is completely false and a common mistake. You do not need relays to do both, just connect both sidemarker wires to signal and parking light power. It will ground off the other power wire.
Old Jul 23, 2005
TheSmuggler's Avatar
The green one I believe will keep them fof and only blink when the turn signal blinks =)
Old Jul 23, 2005
http://www.7thgencivic.com/forums/sh...d.php?t=155302
Steps 7 & 8
Old Jul 23, 2005
yup green is only blink.
Old Jul 23, 2005
Green > all
Old Jul 23, 2005
green + red. no black. false ground = cool.
Old Jul 27, 2005
djspot's Avatar
fuk tha man!
djspot is an unknown quantity at this point
so there is no problem with out having a ground????
Old Jul 27, 2005
its fine if you want them to flash AND stay on.
Old Jul 28, 2005
xHoteKx's Avatar
Tomotor
xHoteKx has a spectacular aura aboutxHoteKx has a spectacular aura about
so thats how you get it to stay on and blink. i always put it off since i have no clue what the **** a relay is n all that. hmmm, might have me a lil project to do tonight
Old Jul 28, 2005
you can even make your parking light blink!
Old Jul 28, 2005
xHoteKx's Avatar
Tomotor
this is odd.. i got the ground wire hooked up to the parking light wire and my sidemarker wont even turn on.
yes, the power wire on the sidemarker is hooked up to the blinker wire
Edit:
haha, i hooked up the ground wire from the sidemarker to the red/yellow wire connected to the turn signal. wow, i feel like an idiot
Old Jul 28, 2005
well it should work. I've tried it. Um you want the parking light wire on the same bulb, ie the turn bulb. So both wires should be connected to one bulb, the corner blinker/signal bulb (has three wires, you want one to red, one to green).
Old Jul 28, 2005
xHoteKx's Avatar
Tomotor
i did that and the sidemarker wouldnt even turn on. but when i put the ground wire to the red/yellow wire connected to the parking light, it worked. but for some reason my passenger side wouldn't work. i think the wire tap might be the culprit since it looked kinda corroded. either that or the bulb burned out.
my passenger parking light bulb has been burnt out. would that have to do with anything?
Old Jul 29, 2005
well maybe, but the wire should still be live. I think you have bad taps. Its a very simple wiring procedure and hard to mess up. Get new wire taps.
Old Jul 29, 2005
jeubs this took me about 30 seconds to wire both LOL
Old Jul 29, 2005
ragingSPAM's Avatar
jesus this thread is old...anyways it took me about 30 seconds to do it too...lol...im gonna splice in a relay so its on all the time and blinks too
jaje
38
May 16, 2009 12:29 AM
0100010
Aug 6, 2008 09:22 PM
oneqwkfbody
Dec 15, 2001 08:50 AM
netcbc
Nov 16, 2001 03:23 PM
civicPRODIGY
Nov 12, 2001 09:32 PM
