Projector problem
Old Jun 21, 2005
Jesjr's Avatar
Jesjr is an unknown quantity at this point
Projector problem
I have halo projectors, with seperate bulbs for lights and the brights. I've had them on for two years. Recently I turned on my headlights, and the drivers headlight doesn't come on., But the brights on both sides faintly come on. Then when I hit the brights switch only the passenger side bright correctly works. I tried replacing the drivers headlight but it still doesn't work. And when i turn on the headlights, the brights indicator in the dash faintly appears as well. You guys know what the problem is, or how i can fix it? Thanks much.
Old Jun 21, 2005
dirtySAMURAI's Avatar
I log in from time to time
Check the stock wiring harness. You might have melted your wires or, if you're lucky, blown a fuse. Check the fuse box for the left/right headlight fuses and see if they're still a continuous line and not blown up. Also check to see if your bulbs are not the culprit. If you're using high wattage bulbs (110/120watt as opposed to stock's 55/60watt), then that will cause problems with the electrical system.
carid
Jun 5, 2015 11:51 PM
Professional
Jan 6, 2002 11:42 PM
vietnam
Dec 21, 2001 02:10 PM
Hondasport01
Dec 17, 2001 01:53 PM
DaPipeLayer
Nov 14, 2001 08:06 AM
