how to aim coupe 01-03 headlights up/down
Old Jun 5, 2005
jttegx's Avatar
OMNES AD UNUM
after reading the DIY and other few threads, im still having trouble adjusting my OEM housings up/downward. on coupes, i seen an piece thats colored light brown/gold thats located right behind the headlamp itself and sits next to the rear of the bulb. looks like it needs a alen/hex key wrench to move that piece.
then theres the bolt that sits right at top and it doesnt nothing but tighten the headlight in place or loosen to remove the headlamp itself. seems like messing with this bolt wont do much for aiming.
the first 3 pics are from passenger side headlamp. you can see the hex key brownish piece and the bolt that screws on to of the headlamp assembly which does nothing
i also took the bolt out to show you where it connects and it looks like it just holds the headlamp in place?
the last 2 pics are the drivers side headlamp. its the exact same as the passenger but i took photos of it just in case.
can someone point me in the correct direction on how to aim my OEM housings higher? its a 01-03 coupe
Old Jun 5, 2005
dirtySAMURAI's Avatar
I log in from time to time
use the allen key to turn the brownish piece. you stick it in through the hole on that top arm of the headlight where it says "U \_/ D"
Old Jun 5, 2005
jttegx's Avatar
OMNES AD UNUM
so use a alen key wrench to hold the brown piece, and stick a phillips screwdriver in the gap underneath the bolt and twist left/right ?
will the brown piece move or should i be twisting the brown piece?
Old Jun 5, 2005
what?
no, just use the allen thing and stick it into the brown piece that is shaped to receive the allen thing. then twist it so the beam moves up or down
Old Jun 6, 2005
jttegx's Avatar
OMNES AD UNUM
what size allen key?
my hand is pretty big, what do you use to get some slack into the deep gap
Old Jun 6, 2005
Xenin's Avatar
Superior Evolutionary Element Destined-factor
Xenin is an unknown quantity at this point
so thats how you aim them! i always wondered how i was supposed to do that cuz one of my headlights is aimed higher than the other.
Old Jun 6, 2005
let me take some pictures and i'll be right back...
Old Jun 6, 2005
hope this helps
Old Jun 6, 2005
masarak's Avatar
master of the culinary martial arts
masarak is a glorious beacon of lightmasarak is a glorious beacon of lightmasarak is a glorious beacon of lightmasarak is a glorious beacon of lightmasarak is a glorious beacon of lightmasarak is a glorious beacon of light
That last post needs to go in the DIY forum.
Old Jun 6, 2005
jttegx's Avatar
OMNES AD UNUM
thanks infinite012, it really helped . i agree with masarak, it should be a sticky or DIY to adjust headlights for OEM housings cause im sure i wasnt the only one with trouble aiming them on stock headlamps.
im curious to know what that wire is for? im guessing ground?
and why's your rubber circle boot loose as well?
and i cant believe the manual tells you to go seek a professional honda tech to aim headlights those shady *****
Old Jun 6, 2005
the wire is a grounding wire for my HID ballasts. rubber boot is loose? i'm guessing you're talking about that thing to the right of my headlight. it's "loose" cause if it's pushed in any more, then my hood rattles.
and as for the last comment: yes, they (honda) just want your money.
Nalmonte
Jul 22, 2015 09:08 AM
breanna_17
Jul 21, 2015 04:01 PM
m.colley
Jul 20, 2015 04:48 AM
Theshwartz35
Jul 18, 2015 10:49 PM
vtec92
HIDs and Retrofitting
Jul 16, 2015 03:55 AM
