OEM replica/Relay question
Old May 10, 2005
cosmo's Avatar
cosmo is an unknown quantity at this point
I've got some OEM replica fogs, and the wiring harness is anything but complete. What I plan to do is use the factory day time running light to trigger a relay and draw power directly from the battery. Will I be able to use the one that came with the kit or do I need something completely different? Any ideas are welcome.
Old May 10, 2005
dirtySAMURAI's Avatar
I log in from time to time
If the relay is on a relay socket, then you can easily pull the relay out of that and use some spade connectors and use the relay like that. If the relay is hardwired to the foglight wiring, then cut the wiring, then retap them after you finish rewiring.
Old May 10, 2005
cosmo's Avatar
There's no socket for the relay on the wiring I recived. It's a non-Bosch relay, so I tested it and have figured out which terminals are doing what. I'll go soft wire everything in tonight maybe to see if it will work.
honda.lioness
16
Feb 10, 2017 10:53 PM
heliboy04
Aug 1, 2015 03:13 PM
hayden55
Jul 8, 2015 11:38 PM
BootyDo
Jul 7, 2015 06:06 AM
hatch90
Jul 5, 2015 01:17 AM
