high temp caliper paint ok for blackout lights?
Old Apr 20, 2005
dinglenuts's Avatar
dinglenuts is an unknown quantity at this point
I've got a can of gloss black high temp caliper paint I want to use on my blackout headlights, any reasons I shouldn't do this... ie gloss?
Old Apr 20, 2005
booba5185's Avatar
7thgen Terminator Ninja
booba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to behold
either gloss and some spray paints would eat plastic, i doubt it would do that with this app, but i think the gloss wouldn't so good
Old Apr 20, 2005
soonercivic's Avatar
soonercivic is a jewel in the roughsoonercivic is a jewel in the roughsoonercivic is a jewel in the roughsoonercivic is a jewel in the rough
it should be fine as long as you use a plastic primer for it. the caliper paint is intended for metal so if you dont prime it, then it wont last.
Old Apr 20, 2005
ironchef's Avatar
There is no substitute
ironchef is an unknown quantity at this point
Most high-temp paints are either enamel or ceramic paint. I'm thinking that this might not be good for this application since it might block too much light. If this is the case the housings might overheat. Sure, the paint won't be damaged, but you might melt something in there.
I think using the spray tint is your best bet, but if anyone can tell me otherwise, then that's great.
Old Apr 21, 2005
i dont think he means black out the lens. i think he means black out the chrome inside. I actually used some plastic primer and had the nighthawk black paint put in a spray can and did mine the exact same color as the car. it looks pretty good with that blue metal flake.
Old Apr 21, 2005
ACURAwerx's Avatar
ACURAwerx is on a distinguished road
i used 99 cent flat black from home depot with no primer.. worked fine, paint dripped in some areas, but you can't see it unless u are looking for it
Old Apr 21, 2005
ironchef's Avatar
you're probably right. That should be fine then.
Old Apr 21, 2005
skiboard's Avatar
BBQ Paint worked
Old Apr 21, 2005
ironchef's Avatar
I guess you would need something that's somewhat heat-resistant, like bbq paint.
Old Apr 21, 2005
the caliper paint usually has a temperature rating of 500 degrees
Xuhme
21
Aug 7, 2023 03:40 PM
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
usajags84
15
Aug 19, 2015 03:12 AM
supercivic01
South
Nov 30, 2001 11:27 AM
autobots
Nov 29, 2001 07:27 PM
