projectors w/ HIDS
Old Mar 10, 2005
T's Avatar
T
T is an unknown quantity at this point
projectors w/ HIDS
I drive a 02 civic sadan. I am trying to hook the HIDs up to my projectors, they originally take h4 bulbs. I tried the 15 and the 25 amp fuses and it does not work. They work when I connect them to my highbeam but not my low beam.
Do you have any idea why they do not work?
Old Mar 10, 2005
wonderz's Avatar
wonderz is on a distinguished road
you might want to be more specific here. what u mean by connecting them to highbeam and how doesn't it work in low beam (blown fuse, just won't turn on, etc)? are you sure you tapped in the right wire for low beam?
also having HID shouldn't not require you to change to a higher current fuse.
Old Mar 10, 2005
civicpride's Avatar
civicpride is an unknown quantity at this point
i have the hid's on my car. get u a test light and see what wire is your low beam one. u should not have to cahnge the fuse out. if it not working your relay could have went out or your boxes. the bulbs could have went out but u would have known it. when my bulb went out, when i turned it on they would flicker. also check your ground.
Old Mar 11, 2005
injencivic's Avatar
injencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of light
moved to Lighting.
Injen
Old Mar 11, 2005
dirtySAMURAI's Avatar
I log in from time to time
i'm going to assume you bought a plug and play kit. good job.
Old Mar 11, 2005
AlienX's Avatar
AlienX will become famous soon enough
FYI: your 01-03 linky doesn't work...
Old Mar 11, 2005
oh sheeet! i deleted the page.
BLACKex613nin
Aug 12, 2003 11:31 PM
NOSVtech
Mid Atlantic
27
Jun 2, 2003 01:24 PM
2k2vtecEX
May 22, 2003 02:48 AM
pdxbiker
Aug 23, 2002 01:50 AM
