Dam HID problem
Old Feb 14, 2005
VTECTypeR's Avatar
Dam HID problem
Ok so I just noticed that my left bulb doesnt turn on anymore. Every time I turn it on it just flickers for a couple seconds and stops. What could be the problem
Old Feb 14, 2005
gh0st's Avatar
TAQUITOS!!!!
double check all your wiring and connections. what's your setup?
Old Feb 14, 2005
VTECTypeR's Avatar
I have no idea what the brand is. I have to check. All I know its 8000k haha
Old Feb 14, 2005
chrisleecool's Avatar
check your wiring
Old Feb 14, 2005
VTECTypeR's Avatar
I just checked all the wiring. Looked good to me. I noticed when I took the ground wire out. It stopped working totally. Then I moved the ground wire location and the flicker lasted a bit longer. Do you think my ground wire isnt in good condition or theres somethin wrong with it
Old Feb 14, 2005
kkk's Avatar
kkk
kkk has a little shameless behaviour in the past
take out the bulb and the ballast which is giving u the problem and connect it directly to the battery of ur car. if it still flicks, then i think say good bye to ur ballast if it doesnt , check ur wiring , fuse etc.
Old Feb 14, 2005
kkk's Avatar
kkk
Old Feb 14, 2005
TuRtLE714's Avatar
TuRtLE714 will become famous soon enoughTuRtLE714 will become famous soon enough
Take out that bulb and connect with the working side ballast....if it dotn fire up with the working ballast then its the bulb. also check all fuses and relay fuse
Rogelio Rey
May 24, 2015 08:30 PM
terry_tr6
HIDs and Retrofitting
May 16, 2015 08:37 AM
Professional
Jan 6, 2002 08:27 PM
0100010
Jan 6, 2002 12:54 AM
