FYI: Higher Kelvin rating does NOT mean more light output!
Old Feb 13, 2005
dirtySAMURAI's Avatar
I log in from time to time
Here is what I'm talking about:
4100-4300k is what OEM car makers use in their cars. Manufacturers such a BMW, Mercedes, Lexus, Toyota, Honda, etc. They will stay with 4100-4300k and never go beyond it, with the exception of BMW. BMW has a seperate "color-matched" bulb that you can buy which is essentially a 5000k HID capsule. It mimics a properly color-shifted HID capsule while losing some lumens.
5000k is getting on the bluer side. While you can still see [almost] perfectly fine with these, you are sacrificing lumens. Less lumens = less visibility.
6000k is worse.
8000k is even worse.
12000k - hahahahahahahhahahahahahahahahahahha. Don't even bother with that unless you like having black lights for headlights.
Old Feb 13, 2005
This next part I'm going to be taking from HIDPlanet.com/forums
Bulbs
Ok, first off, lets start with the bulbs. The common mistake some people here is that all these high kelvin rated bulbs are the shizzle. Well, they couldn't be more wrong. The higher you go in kelvin, the less light and lumens you'll have. Pratically anything over 6k is really a waste if your at all concerned with your safety and brightness of lighting. So what is the best bulb out there then you ask? 4100-4300k. It has the most lumens out of all the HID bulbs produced. Thats why car manifacturers still use them today. Below is a graph showing you the variances of the light spectrum. As you can see, 4100k would be right where the "sweet spot" is on that chart. It produces near to the suns same kelvin thus giving you daylight-like output. Think of it like this, high kelvin bulbs would be like being out in the sun with sunglasses on vs a 4100k being in the sun w/o glasses on.
Also here is another good thing to know taken from the FAQ:
Yellow:
1500 k Candlelight
2700-2900 k Yellow painted fog halogen bulbs
Yellowish white:
3200 k Sunrise/sunset
3200 k Premium H7 non painted halogen bulb
3400 k 1 hour from dusk/dawn
White:
4100 k Philips/Osram OEM HID D2S
5500 k Bright sunny daylight around noon
Blueish white
5500-5600 k Electronic photo flash
6000 k Philips Ultinon HID D2S
6500-7500 k Overcast sky
Blue:
9000-12000 k Blue sky
Purple:
28000 Northern sky
12000-30000 k Ultra Violet light (black light)
Some important terms to know:
Watt- Measure of electrical power (w)
Volt- Measure of electrical charge (v)
Kelvin- Measure of color temperature (K)
Lumen- Measure of light brightness (lu)
Candela- Measure of light intensity (cd)
Ampere- Measure of electrical current
Cut-off- A distinctive line of light produced by the shield in a headlight that blocks light above a certain height in order to prevent blinding of other motorists.
Beam Pattern- The pattern of light that is projected onto the ground which includes angle of lateral dispersion, width and depth of illumination.
Capsule- Another term for an HID bulb. Some refer to HID bulbs as gas discharge capsules.
Optics- The lighting control assembly structured around the bulb, which effects the dispersion of light and it's characteristics to a great degree.
HID (High Intensity Discharge)= Gas Discharge
Halogen= Incandescence
Old Feb 13, 2005
ImPulse's Avatar
Basically anything over 6000k is bad...
Old Jun 9, 2005
Yea those kelvin temperatures are actual temperatures of stars in space that emit a certain color. That's where the color scale came from. That's why if you have halogen bulbs, stock is brightest (clear bulb), but coated bulbs that make the light whiter actually filter out some of the visible light.
97-DX-Lover
Jun 14, 2015 06:07 PM
Black91civic
Jun 6, 2015 08:15 AM
kiluminati001
Dec 13, 2001 09:17 PM
PimpBot5000
Nov 26, 2001 07:15 PM
klam
Nov 16, 2001 03:36 PM
