Disable DRL?
Old Feb 9, 2005
RIC3BOY's Avatar
RIC3BOY is an unknown quantity at this point
Disable DRL?
Anyone know how to disable DRL's? I've done a search but no results.
Old Feb 9, 2005
dirtySAMURAI's Avatar
I log in from time to time
are you sure you searched?
i'm thinking it's a fuse. search in your owners manual or in the fuse box locations for more info.
Old Feb 9, 2005
AggressiveAdam's Avatar
AggressiveAdam will become famous soon enoughAggressiveAdam will become famous soon enough
There is two DRL fuses, one under your steering coloum and another one I think in your glove box.
All I did was take the panel under the steering colum off, theres a diagram off all your fuses. look for DRL, and pull it. Kinda tricky to do with stubby fingers so if you have a set of needle nose plyers make the job easier
Old Feb 10, 2005
RIC3BOY's Avatar
I've taken out the 1st fuse under the steering column before, and nothing happened. Where's the one in the glove box? I thought there were only 2 sets of fuses: (1) under the steering column, (2) under the hood near the battery.
I remember seeing a thread somewhere about this. But the search isn't returning anything for some odd reason, weird.
Old Feb 11, 2005
hmm worked for me. Thats werid are you sure you pulled the right fuse?
as far as the second set of fuses yes perhaps by your battery. I wasnt sure, check the diagram they label it DRL.
For you Yanks DRL stands for Daytime Running Lights
Old Feb 12, 2005
i'm pretty sure us yanks already knew that. we've got cars here that have drl too.
solarpunk70
Apr 12, 2016 11:43 AM
mac25
Aug 21, 2015 11:14 PM
FurBall
Aug 29, 2002 02:57 AM
netcbc
Jul 13, 2002 02:22 AM
