Installing headlight bulbs on 2004 civic
Old Jan 21, 2005
nawaf88's Avatar
nawaf88 is an unknown quantity at this point
I have a 2004 civic and I want to change my headlight bulbs. I just poped open my hood and noticed that its very difficult to reach the drivers side headlight for the low beam. Its dark out but it doesnt seem that I can reach it with my hands because there are too many things in the way. Do you have to some how remove the whole headlight assembly to get to it? Any help would be appreciated. Thanks
Old Jan 21, 2005
jeffsta17's Avatar
jeffsta17 is an unknown quantity at this point
there is a resevoir in the way with oil or something right? I dont remember exactly what its for put just pull up and wiggle a little bit and it will pop off its mount. Then move it to the side. Thats what I did. Just make sure to put it back before trying to close your hood.
Old Jan 21, 2005
genx_7's Avatar
genx_7 is an unknown quantity at this point
you have to go through the fenderwall to reach parking light and turn signal. your manual explains in depth. Just take out the tab that holds it in with a flat screwdriver and bend the fenderwall back and you can reach it.
Old Jan 21, 2005
nawaf88's Avatar
thanks guys, i just checked my manual and it states how to do all this. I appreciate you help
Old Jan 21, 2005
manahoonie's Avatar
what a concept, checking the manual.
Old Jan 21, 2005
nawaf88's Avatar
lets not be a deuche
Old Jan 21, 2005
Civic_RedLine's Avatar
im stock now! T.T
Civic_RedLine will become famous soon enough
you can reach your stock bulbs. you "cant" reach if you dont try hard enough. drivers side has power steering pump (brown with red cap), pull that up and put it aside. Do not complete remove it just push it a little aside while you change the bulbs. if you have projectors just remember to use h1 bulbs. ooops, they dont have projectors for the 04s do they?
Old Jan 22, 2005
I FuSe I's Avatar
I FuSe I has a little shameless behaviour in the past
Mine was still a pain in the *** to take out. I just took the whole housing out.
Old Jan 22, 2005
im stock now! T.T
what do you mean? the headlight itself? u gotta remove bumper for that.
if you talking bout bulbs, ur hands must be big foots hands. its not tha t hard if you arent scared to get a couple scratches on ur hand.
bsmiley
Apr 27, 2015 01:27 PM
shaejb15
Apr 26, 2015 07:44 PM
chgofirefighter
Apr 18, 2015 08:08 PM
0100010
Aug 6, 2008 09:22 PM
CivicBR900EX
Sep 5, 2001 10:27 PM
