Hid Question
Old Jan 17, 2005
T's Avatar
T
T is an unknown quantity at this point
Hid Question
I bought H3 HIDS for my car and I ordered projectors for my civic. Will these HID fit and work properly?
sorry, kind of a really broad question.
DUAL HALO projectors!!~~ the way to go ^_^
Old Jan 17, 2005
Stachmo's Avatar
"You leave me in the trenches taking Grenades, John"
Stachmo is an unknown quantity at this point
well usually civics are all H4 Bulbs...
I dunno if anything is different for your halo lights..where did you get them? I think you may be outta luck with the blubs though
Old Jan 17, 2005
Pb4uGo's Avatar
Pb4uGo is an unknown quantity at this point
most aftermarket lights using seperate housings for low/high beams are H3 or H1, as long as the projectors you purchased are H3 there should not be a problem, just be aware that really only the TYC aftermarket lights really rival the OEM housings for ight output, so while with HID you may throw more light, the beam pattern may not be as good.
I have the McCuloch H4 Halogen High/HID Low kit in my stock housings and am more than pleased with the light output.
Old Jan 17, 2005
skipbarber's Avatar
TYC is H1 as a matter of fact...i think all projectors for the 7thgen are H1. I dont know how different H1 is from H3.
Old Jan 17, 2005
FALKEN's Avatar
Civicforums Junkie
moved to the Lighting forum
Old Jan 19, 2005
gh0st's Avatar
TAQUITOS!!!!
search the HID pic post for results on what a HID kit will look like in aftermarket projectors
http://www.7thgencivic.com/forums/sh...d.php?t=164422
Old Jan 19, 2005
wonderz's Avatar
wonderz is on a distinguished road
my projector uses h3 for low beam and h1 for high beam.
the main difference between h1 and h3 is just the base. you can basically cut out a small part of a h1 base to make it fit into a h3 based housing and vise versa. For the halogen bulb i believe h1 is slightly longer, but for HID i guess that doesn't matter since they would probably be the same length.
Old Jan 20, 2005
AggressiveAdam's Avatar
AggressiveAdam will become famous soon enoughAggressiveAdam will become famous soon enough
keep in mind for them to look good togheter you need a retrofitted lens, not the crappy lens it comes with
Old Jan 21, 2005
LowRYda03ex's Avatar
LowRYda03ex is an unknown quantity at this point
do u know of any certain housings that have been known to overheat with HID's?
tuvok
Sep 25, 2015 03:13 PM
JMKendrick
Sep 16, 2015 06:17 PM
junkyardguy
Sep 2, 2015 06:07 PM
herbiej
22
Aug 23, 2015 01:02 PM
martinsmartin
Aug 15, 2015 07:34 PM
