Angeleye Projector question
Old Jan 8, 2005
flyguy050's Avatar
flyguy050 is an unknown quantity at this point
I have found that when you put aftermarket xenon bulbs in the halo projectors (I have 4750k piaa's) that the light is not strong at all. Does anyone know how to wire the lights so that both the low beam and high beams come on when the high beam switch is turned? If not, does anyone know where the headlight relay switch is located?
Old Jan 8, 2005
Rufus's Avatar
You need a diode in line to let power to the lows ALWAYS but to the lows as well when you turn on the highs
Old Jan 8, 2005
wonderz's Avatar
wonderz is on a distinguished road
yea, a diode is the easiest way. but they don't work for HID if you decide to get them
well, at least the diodes that u find in radioshack, haha.
and they get pretty hot, so u might want to wire them good.
another way would be to make yourself a relay harness. there are no relays in the headlight that u can use.
robjcivic
Mar 12, 2017 12:10 PM
wingsfan19
Oct 1, 2015 03:45 AM
JMKendrick
Sep 16, 2015 06:17 PM
junkyardguy
Sep 2, 2015 06:07 PM
martinsmartin
Aug 15, 2015 07:34 PM
