making custom LED TAIL LIGHTS
Old Oct 31, 2004
CvC-v01's Avatar
CvC-v01 has a little shameless behaviour in the past
Arrow making custom LED TAIL LIGHTS
for my next project i would like to make custom LED tail lights but i was wondering if you guys know of any web sites that would help me complete my project...
i found this link but i'm not familiar with circuit boards...i just need sometime a bit simple for me to do....
http://www.nissanclub.com/forums/sho...ck+tail+lights
can you guys please help
Old Oct 31, 2004
Ed's Avatar
Ed
If you want, you can get stock sized replacements online. http://www.ledtronics.com/datasheets...auto_index.htm
They don't have the LED array look that you're looking for though. What more help do you need?
The circuit boards are very straight forward. All you do is wire all the leds up in parallel, then add up the current. I don't quite like what the guy in that thread did though. I don't like that he just took the voltage/current.
Because there is a voltage drop across the resistors, you should really take the (12-led voltage)/current, and use that as the series resistor value.
Are you looking to make an LED array like that?
Old Oct 31, 2004
Ed's Avatar
Ed
I think his way, the current will be a little less, which I guess is better than having it too high, I suppose of you consider a car battery ranging from 12-13+ volts, then it would be better, but it would be better to do it the right way and account for the voltage differences.
Old Oct 31, 2004
Vinnie's Avatar
Vinnie should not be trustedVinnie should not be trustedVinnie should not be trustedVinnie should not be trusted
wow that sounds like an intense project. Good luck and be sure to make lots of updates.
Old Oct 31, 2004
MegaHurtz's Avatar
wow that is a hell of a lot of LED's...
I saw that on a car before, I think it was a newer 7 series BMW... it looked awesome, I think it was even stock.
Old Nov 1, 2004
CvC-v01's Avatar
I plan to do an array like but i don't want to sauder all kinds of resistors to led bulbs on the circuit board.....
what do you reccomend is best to do...
Old Nov 1, 2004
PopcornPlaya's Avatar
Electric Boogaloo...
You might want to post this in the subforum lighting, and let ImPulse handle it. He's done the LED's in the 04 tails. I'd ask him, as he "knows whats the fvcks is goings ons..." I think he posted a set of progress pics at one time, but not sure.
Old Nov 1, 2004
Ed's Avatar
Ed
It's really very straight forward. Connect up all the anodes of each LED, and connect all the cathodes of each LED [this arrangement is called Parallel]. Then, you connect one resistor, of the value calculated above, in series with all the LEDs.
Old Nov 1, 2004
MegaHurtz's Avatar
Moved to Lighting
Oh wait I don't have that power
Old Nov 1, 2004
CvC-v01's Avatar
how do i get of hold of Mr. IMpulse?
Old Nov 1, 2004
Umm... he'll see it soon enough. I'm sure he'll respond. If not, just browse the lighting subforum, where this is located now.
Old Nov 2, 2004
AggressiveAdam's Avatar
AggressiveAdam will become famous soon enoughAggressiveAdam will become famous soon enough
Originally Posted by MegaHurtz
Moved to Lighting
LOL
Old Nov 5, 2004
ImPulse's Avatar
I' am not 100% done... The main problem with doing a custom led conversion is Heat... You dont want the leds to die or your tails to get messed up...
Anyways, Whenever I drive around at night time I basically look for cars that have LED tails then follow them , There are ways to make the leds either just stay on.... or blink for turn signal use. So, there are a whole bunch of wiring/technical things you gotta know
this is what i want my 04s to turn out like...
But, because of heat issue and all, I believe I will only be making the top "section" LED and the rest halogen. Still not sure.
here are some LED DIYs
http://josch.wilksfamily.com/3rdBrakelight.htm
http://home.comcast.net/~jbipes/ttr/ledtails.html
Old Nov 5, 2004
Ledbelly's Avatar
Im the man in the box
just wondering but wouldnt this be illegal because your not supposed to mess with the braking system ?
Old Nov 5, 2004
ImPulse's Avatar
Whats illegal? It came with the car
(as long as everything works perfectly, the LEDs exceed oem ability, So, I dont see a problem)
Old Nov 5, 2004
Rufus's Avatar
No cop would EVER know anyway
Cop: You know why I pulled you over son
You: No officer was I speeding?
Cop: Speeding? Ha, if you were only that lucky. It's pretty obvious that this vehicle should have short life, boring, and less effective halogen bulbs in the tailllights. So what the hell are these far superior, longer lasting, LED's doing in here? Let me check my code book cuz I might need to take you downtown.
You: Hey Officer do you know what old pennies are made out of?
Cop: What?
You: Dirty Copper!
Old Jan 27, 2005
Ed's Avatar
Ed
Just an update, I'm gonna go ahead and do this I have an extra set of tails in the mail, i addition to 1000 LEDs, and some resistors.
Poopies
Apr 20, 2017 11:36 PM
Erndog81
Oct 31, 2015 03:01 PM
shaejb15
Apr 12, 2015 11:38 AM
reLaXedinca
Nov 2, 2001 06:44 PM
