I Have to push a button to turn on indiglo gauges
Old Sep 11, 2004
sf2ryu's Avatar
sf2ryu is an unknown quantity at this point
Angry I Have to push a button to turn on indiglo gauges
I bought these $17 reverse indiglo gauges off ebay. I am happy with how they look and how they look lit up, but I am disappointed because in order to turn them on, I need to push the on/off button which came with the gauges. I know this is going to annoy me, as I will have to first turn on the light switch, then dig into my change drawer, where I placed the on/off switch to turn it on. Is there any way that I can modify the wiring so that the gauges automatically turn on when I switch the lights on, and bypass having to use the on/off switch that came with the indiglos? I tapped the red (non-ground) wire into the red/black wire in the blue harness. Help Please!
Old Sep 11, 2004
turboslug's Avatar
Super Hoser
turboslug will become famous soon enoughturboslug will become famous soon enough
use a relay to turn the power on and off?
Old Sep 11, 2004
sf2ryu's Avatar
What is a relay and how does that work?
Old Sep 11, 2004
TheSmuggler's Avatar
own3d lololol ololol
Old Sep 11, 2004
turboslug's Avatar
Super Hoser
it's basically a switch that uses an electrical current to turn it on/off
Old Sep 13, 2004
Mystic3030's Avatar
Yup, i'm an A$$hole.
Get a wiring diagram for your OEM guage cluster, find the wires that activiate the illumination in that, and tap them instead of running wire to a switch.
To the moron that said "owned" why is he "owned" because he didnt know what a relay was?
Old Sep 15, 2004
sevenplaces's Avatar
I want a TSX!
sevenplaces is on a distinguished road
tap the power wire for the gauges into the plug that goes on the left side (when youre facing it as a driver) of the gauge cluster. I think the wire is red with a black stripe that you need to tap into (double check the wiring diagram on this website). Then I just put the ground from the indiglo's on one of the mounting screws for the gauge cluster. Works like a dream!
Old Sep 15, 2004
baggedblue02's Avatar
baggedblue02 will become famous soon enoughbaggedblue02 will become famous soon enough
Cut the wires going to the switch and straight wire them, then hook the main power into any wire that has power when you turn on the lights
Old Sep 16, 2004
J187's Avatar
J187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of light
Mystic3030, what do you think he means by, "smugglin' Bananas"??
Old Sep 17, 2004
Caucasian.Asian's Avatar
why didn't you wire them to your headlights? thats how mine are. i used the DIY thread on here. can't find it though
Old Sep 20, 2004
paradoxblue's Avatar
wish i coudlg et indiglo for th e04 :'(
Old Sep 21, 2004
civices8353's Avatar
civices8353 is an unknown quantity at this point
you can tap any dim positive (such as the dash light or maybe an ASH TRAY light) directly
gearbox
Electrical DIY
72
Nov 27, 2015 08:13 PM
dinsum
May 28, 2015 09:30 PM
LX2slow
Dec 20, 2001 08:33 AM
manicEL
Dec 10, 2001 06:33 PM
nickfn
Nov 30, 2001 11:13 AM
