question about HIDS
Old May 9, 2004
platano's Avatar
platano is an unknown quantity at this point
Question question about HIDS
I'm here trying to get info on HID's for my car. I know that I don't want anything any higher than 4300k. What's the best kit to go with? Where can I get a pair of HID's for the cheapest price? At the same time I would like to see if I can match the OEM foglights with bulbs too. Where can I get some bulbs to match?
Old May 9, 2004
ImPulse's Avatar
only kits i recommend are, Catz or Philips
>> Ebay.com
Old May 9, 2004
platano's Avatar
What about retrofitting a set of Halo projectors? Will this be good to go or will it be a waste of time?
Old May 10, 2004
platano's Avatar
What is retrofitting anyway?
Old May 11, 2004
LiKEaFeRiO's Avatar
Read Impulse's FAQ; the link is in the signature.
Retrofitting is taking a headlight system made for HIDs and some custom work to make it fit in your car (which does not have HIDs).
I don't think you'll ever find a bulb to match the "whiteness" of the HIDs. Maybe some multi LED bulbs but not sure.
Like Impulse said, I'd recommend CATZ.
I dont think Phillips makes an HID "kit." Kit meaning an Phillips brand ballast, ignitor, and bulbs.
I believe Phillips just makes bulbs (called Ultinon) and the "kits" are usually packaged with Hella or some no name asian ballasts/ignitors and sellers just call them a Phillips kit.
The best kit to go with?
If money isn't an issue I'd recommend some Bellof Spec Le Mans HIDs.
This kit was engineered for use in endurance races such as the Le Mans 24hour and the Daytona 24hour. Around $1500. =)
Old May 11, 2004
platano's Avatar
I appreciate the info. I'll check the HID FAQ on Impulse's signature. If there's anything else that anyone may think of that may hit me up with some more insight on this, i'll greatly appreciate it. thanks.
Old May 12, 2004
dragoon's Avatar
>> Ebay.com
Phillips does not make HID kits.
Neither does Hella.
I recommend Catz and McCulloch, if you can find them.
Old May 12, 2004
ImPulse's Avatar
Well, its called the "Philips Kit" lol, jeeze i know they dont make the full thing. Whats he gonna search for, Fake philips HID kit?
McCulloch is bad, There bulbs pop within months.
Bellof Spec Le Mans HIDs :x yea... LOL, Good luck with those
Old May 12, 2004
dragoon's Avatar
Strange, I know 5 or 6 people with McCulloch kits that have had them for well over a year without a single problem. I personally have had mine for just over a year, as well.
And yes, search for Fake phillips HID! At least those would be honest, and probably cheaper.
Most P&H kits have ballasts pulled from junkyards, defects, or worse, fakes.
Old May 13, 2004
LiKEaFeRiO's Avatar
If the employee didn't mention the fact that the Spec Le Mans are strictly for off-road and are illegal for street use, I would have bought them!!
But yes, go with Bellof for the best HIDs!
Old May 13, 2004
platano's Avatar
How much are those Bellof HIDS go for? Where do I look for them. Right now I'm in Japan and doing as much research I can before I go with a certain kit. I REALLY APPRECIATE THE INPUT GUYS!!!! Thanks.
Old May 13, 2004
platano's Avatar
Okay another question.....What bulb size will I be looking for to fit with the aftermarket HALO projectors? Thanks.
Old May 13, 2004
platano's Avatar
These are the ones I'm talking about putting HIDs on. Will I need to retro fit them? If I do what retro fit projector lens should I go look for to do the mod?
Old May 14, 2004
LiKEaFeRiO's Avatar
I got mine from AutoWave in Tokyo. Open 24/7!!! I bought mine at around 1am =P
Roughly $1000 for the H4 Spark White 6000K bulbs and the Spec 01 Evolution ballasts/ignitors. You need 2 boxes; one for the bulbs and one for the ballasts/ignitors.
If you want to put them in the projectors you can get H1 bulbs I believe.
If you want better light output and more efficiency, you'll have to retrofit HID projectors.
You need to buy some Bellof bulbs in either D2S or D2R sizes.
But if you do go to AutoWave you'll have other choices from Catz, Piaa, Polarg, etc... good luck choosing!!! I know I had a hard time!
Old May 14, 2004
LiKEaFeRiO's Avatar
The projector lens you can pick up off eBay here.
Just go buy yourself a good HID kit.
Old May 14, 2004
platano's Avatar
Ok cool, So what did anyone do for the HI beam? Did anone just get regular halogen bulb for them or did someone get those hooked up with a HID kit too?
tuvok
Sep 25, 2015 03:13 PM
JMKendrick
Sep 16, 2015 06:17 PM
junkyardguy
Sep 2, 2015 06:07 PM
herbiej
22
Aug 23, 2015 01:02 PM
martinsmartin
Aug 15, 2015 07:34 PM
