HID Problem
HELP!!! My driver's side Headlight is out. I have a Hi/Low HID kit 8000k kit. When I fire them up, I see a little spark but the one side doesn't go on...Anybody else have this problem? Is it possible to get more bulbs/where? Is this just a sign that I should say F*** the Civic and buy the Lexus I want???
lol... Man, Where have u been? havent talked to u in a while.
Well, What do u mean by spark? It could be the bulb or ballast... Take the bulb out of the other headlight and see if it gets lit up... If it does, then you need a new bulb.
If you need a new bulb check out ebay. Seeing that you have an aftermarket kit, the bulbs may break every couple of months (from what ive heard/had happen to me).
Hey Bro - Ugh it's been a stressful few months...new job...new house...HID lights breakin' lol. Uhm, when I turn them on, there's a quick flash of red and then the blue the lights usually are but it doesn't stay on...I was looking under the hood already, and it's is next to impossible to get at those ****ers to even look at the wiring harness...compact cars... haha. If the bulbs are going to have to be replaced every few months I'm going for the new car (IS300 or LX470).
1st day i got my H4 lo HID kit the starter went out...i was chillin at a stoplight then my drivers side headlight started to do some strobing effect then went out.........i got it replaced ... they just said it was defective.... check ur ish from left to right
Second Place is the First Loser
Originally posted by TMRakip
Warranty...I wish...I believe they are Phillips bulbs and Hella Ballasts.
End Bringer
one reason i went with d2s instead of h7
cheaper to replace if it ever blows
have you check your fuses? one of my headlight fuse blew and it would flicker on and off
Rogelio Rey
May 24, 2015 08:30 PM
haha
