So F*in Pissed With My Headlight
Old Feb 27, 2004
chicohonda02's Avatar
Since 2002 Baby!
Angry So F*in Pissed With My Headlight
Sorry for the long story:
AGAIN FOR THE 3RD TIME MY HEADLIGHT BULB HAS GONE OUT ON ME. THINGS LOOOKED DARKER WHEN I PULLED UP TO THE HOUSE AND SO I GO AND LOOK AND MY RIGHT PASSENGER HEALIGHT IS OUT. I AM SO PISSED OFF. I COME TO REALIZE THAT ITS NOT THE BULBS, BUT YET A WIRE PROBLEM. THIS DUDE MY FIANCE USE TO WORK WITH WORKS ON CAR AND SAID HE WOULD INSTALL SOME FOG LIGHTS I HAD. HE DID AND I FELT UNSURE OF THE WAY HE DID IT. MAYBE IT WAS THE RIGHT WAY TO GO AND WIRE THEM.
INSTALLATION: He took "tap-in Sqeeze Connectors" and tapped into the power wire on the headlight. So everytime my headlights turned on, the fog's would turn on below installed near OEM's suppose to go.
After: 6 months go by and the right headlight bulb goes out. So I replace it. 2 more months go by and one of the fog lights break from rocks. I take the fog lights out, but leave the wiring for future replacements. Never happens. A few months later the replacement headlight bulb goes out again. BTW the left one never goes out, but gets replaced everytime the other goes out. So I get fed up and take the old fog light wiring out and UnTap the connector, casue I'm pissed and I felt like that was my problem. Make long story short I've replace bulbs 3 times and I pissed.
Question:
1. Could my headlight wiring be ****ed up completely??
2. Is this under warranty?
3. Could HONDA fix this for me??? (no trace of fog lights, so it looks origonal)
4. WTF DO I DO?????????????????????
Old Feb 27, 2004
NottaCivic's Avatar
NottaCivic is an unknown quantity at this point
Just wondering if it's the stock headlight bulbs or not? I'm not real sure on the wiring part though.
Old Feb 27, 2004
Since 2002 Baby!
I replaced stock bulbs with Eurolite's, then replced those with some sylvania OEM bulbs, those went out, then replaced with some GE White's.
Old Feb 27, 2004
CTICE's Avatar
CTICE is an unknown quantity at this point
It may be the bulbs, I dunno. I used to have the same problem, one of my headlights would go out about every 3 months. I had the hyper white bulbs, so I'm not sure if its cause of that or something else
Old Feb 27, 2004
Since 2002 Baby!
I might go to Honda today or in the next few days.
Old Feb 27, 2004
Since 2002 Baby!
No Honda, I wrapped some electrical tape around the expose wite that looked stripped from its cover. Maybe this will help.
Old Feb 28, 2004
NottaCivic's Avatar
I would say that it was the bulbs. The aftermarket bulbs run on somethin like 85 watts while the OEM or even Sylvania's run at 52 watts. I put some aftermarket bulbs in mine and it actually melted the connecter that plugs in to the back of the bulb socket. I will never get those POS Hyper white bulbs again. I'm gettin HID's in a couple days. But anyways, like i was saying, i would say it was ur bulbs, but since you were running Sylvania's and they still burnt out, then I doubt it is the bulbs, but you never know.
Old Mar 1, 2004
HEBEGEBZ's Avatar
HEBEGEBZ is an unknown quantity at this point
You do know not to touch the glass on the bulb right. Jus checking
Old Mar 3, 2004
Since 2002 Baby!
Never, that would cause them to burn out quicker.
Old Mar 3, 2004
I don't think tapping the fogs onto the headlight wiring was a good idea. It causes the same effect as running high wattage bulbs. I bet it messed up your electrical wiring, since the wires were not setup to handle that kind of current draw.
Old Mar 4, 2004
DestnationUnkwn's Avatar
DestnationUnkwn is an unknown quantity at this point
Honda recently announced it will be recalling about 440,000 2001-2002 Civics because the headlights keep going out. Its a problem with the wiring overheating. Talk to your dealer about it. They should be notifying affected car owners starting this month, March.
Old Mar 6, 2004
Falcon's Avatar
Falcon is an unknown quantity at this point
A) that wasnt the right way to do the install of the fogs
B) it doesnt really matter however
C) if you havent blown fuses, you have NOT damaged the wiring
D) since afermarket bulbs are generally CRAP I would say I'm 95% sure that its the bulbs fault
E) since bulbs have gone AFTER the fogs were disconnected, I would say I'm 100% sure its the bulbs
trust me
Old Mar 10, 2004
Since 2002 Baby!
I wrapped electrical tape around the tap-in spot where there was wiring exposed to moisture. So far its working good. I made appointment with Honda, but cancelled cause I told them I was over mileage. They said then most likely it won't be warrantied. But maybe i should look into that recall ya'll were talking about.
Old Mar 10, 2004
Since 2002 Baby!
Oh, ya and the dude who installed those fog light for me, works at a Lexus dealer as a mechanic. Can you believe it. As soon as he looked at my shift **** that has indiglow and he couldn't figure out how to get it to work, I was thinking to myself, "I'm screwd"
Old Mar 10, 2004
MONTREALCIVIC's Avatar
MONTREALCIVIC is an unknown quantity at this point
if it is the bulbs buy syvania silverstars there great and they last
Old Mar 10, 2004
LuZi0n's Avatar
LuZi0n is an unknown quantity at this point
...nevermind
Old Mar 14, 2004
Voiceofid's Avatar
End Bringer
factory techs are train to do factory work, not aftermarket
all techs will first blame aftermarket, if a problem should arise on the car, it's standard procedure
Old Jun 8, 2005
eyegiant's Avatar
eyegiant is an unknown quantity at this point
I heard that there was a recall on the headlights for some 01 civc, do to the wiring harness, caused the lights to dim down. I don't know if that might be the cause affecting your car.
Old Jun 8, 2005
gh0st's Avatar
TAQUITOS!!!!
welcome to last year.
rnaodm
Sep 21, 2015 12:42 PM
shaejb15
Sep 12, 2015 01:02 AM
Bricoleur
Sep 9, 2015 12:23 PM
MamaBear2015
Sep 4, 2015 09:04 PM
hatch90
Sep 3, 2015 08:45 AM
