my civic
my civic
well the right side of my OEM aftermarket foglight is not working. the left side(driver side) is good but the passenger side (right) isn't so any good suggestions or reasons why its not working? is it the fuse, if so where can i locate the fuse for the fogs? how much would it cost to fix it? they quoted me 225 labor on HONDA which i think is bullshiet.
i really want to fix my foglights so i can see better at night like i used to. thanks for the responses.
Take your right one out and check the bulb, if that dont work check your relays, fuses ect.. Honda is full of shitz they just want your money they wouldnt be that hard to fix at all. It could have blown from condensation getting in it, or if you dont use them that much and u turned them on when its cold, there are too many reasons on why they could have blown. Just start with taking your right one out if you know how to, and check the bulb and trace the wiring (Possible short, or disconnected).
Originally posted by INCivic
wow, 225...talk about a *** raping
Search and Learn
-Check the bulb
-Relay
-Make sure all wires are connected
IF you can't find any problem with fog lights.
Go buy replica oem fog lights for $100 and install them yourself.
Honda is trying to rip you off.
-Relay
locozoko
Nov 4, 2001 05:45 PM
WeRkX
Nov 1, 2001 10:33 PM
