Those with projector style lights - Pros / Cons? Please assit
Old Feb 10, 2004
PunkingCivic's Avatar
I need TP for my bunghole
What are the Pros and Cons?
I need new head lights and would like to get a set.
The Halo ones look cool but do they last.
Please assist before I decide to buy some.
Thanks,
Ray
Old Feb 10, 2004
dragin's Avatar
dragin will become famous soon enoughdragin will become famous soon enough
i hear that tyc has a bad habbit of puttin bee's/bugz in the housing's or stuck in the seal of the lense.....
Old Feb 10, 2004
OK?
I mean the over performance of the lights.
Do they over heat?
poor application (doesn't it fit or is modification required)?
Cracked lenses
lights not aiming properly on the road.
ETC.
Old Feb 10, 2004
bickford05's Avatar
bickford05 is an unknown quantity at this point
just dont get the ebay noname ones and you should be fine. I bought some last summer, and never put them in because the bulbs didnt fit right, and the lenses wernt clear... they had white streaks in them. so anyway i sent them back.
Old Feb 10, 2004
pbfoot's Avatar
i heard bad things about the halos/matrix lights as far as fit and overall quality.
i used to have TYC and liked them quite a bit. it took me a while to figure out how to aim them, but the light output is still a little less than the stock ones. the light is more focused instead of a flood light like the stock housing. TYCs fit perfectly and looked really good.
only reason i switched back was cause i never really wanted to get them. i messed up my lens when i cleared my stock lights, and TYCs were cheaper than a replacement housing. when i found a used one, i fixed my stock lights and went back to those.
projectors are notorious for getting blown bulbs more often than the stock housings.
Old Feb 10, 2004
tripledoublegs's Avatar
Euro-Spec
You might have some visibility problems. I heard theire not as bright as the stock ones.
Old Feb 10, 2004
newshus's Avatar
newshus is an unknown quantity at this point
I've got the tyc projectors in silver. They are a very close match to the factory. I'm going to switch to the "JDM" black housing now though. The only con is adjusting the beams. Its a pain in the butt.
Old Feb 10, 2004
jwalker87's Avatar
Bodacious Member
jwalker87 is an unknown quantity at this point
i have black housed TYC's. THey're really nice; i think they're brighter than stock; they have a much more focused beam. And they look nice. I broke off the side bracket when I wrecked though, so the right headlight is aimed pretty much across the left of the other one; not good. I'll probably be getting rid of them for blacked-out stock lights
I could sell you my set for cheap; they're really nice. Just not me. You could probably get the bracket fixed for about $20 by a shop.
Old Feb 10, 2004
Day_Tripper's Avatar
Owned By Slo Rex
I love my chrome TYC's they work way better then stock but I have heard diffrent of the ones with black housing it just depends
Old Feb 10, 2004
BlueFlame's Avatar
BlueFlame is an unknown quantity at this point
I have the black housing and I really like them
Pros:
- Look better than stock (this is an opinion thing)
- Good Light output, possibly better than stock
- Fit better than most other projectors
Cons:
- come from factory very badly alligned
- If they're not aimed properly, light output is very poor
- Can look worse than stock (again, opinion)
My reccomendation, go with the TYC's & then save up for a HID kit and install that. That's what I have in mine and it is hella sweet. It lights the road up SUPER nice, and once I finally got them aimed properly, I didn't have anyone complaining about being blinded (except the occasional idiot who just doesn't like the HID's period)
Anyways, I reccomend them, & as long as you get the beams aimed right, they work very well. I might not use the Xenon bulbs though, becase the H1 bulbs have a tendancy to burn out very quickly, especially in the TYC's - I learned this the hard way, after about 4 different sets of bulbs ...
Old Feb 11, 2004
samscivic's Avatar
samscivic is an unknown quantity at this point
no problems here
Old Feb 11, 2004
JayFReaZy's Avatar
I have the halo/matrix headlights
pro's
-they look 100x better than stock
-they "blink" change colors at the cut-off points like an audi/maxima/bmw
-had them for close to 2 yrs, no problems with the halo LED's or anything like that, easy install, good fitment.
con's
-not brigther than stock
-fogs up if its not sealed
thats basically it. I herd TYC is just a LITTLE bit more brigther than the halo's, but not that much. I've spent over 6 hrs adjusting my halo's, and it still does not compare to stock. My dad says he cant see **** when he drives my car at night. Only thing really good about it, is its looks. Its hott, thats the ONLY reason y i keep it on.
Old Feb 11, 2004
guamcivic2k1's Avatar
YoUnG N SuXsExFul
i have halos...output sucks...fitment was ok...but my bulb blew in 3 months..so i switched back to my stock ones..
Old Feb 11, 2004
modoman's Avatar
i have the halos and they fog sometimes*, but only when the ac is on and its especially humid.. i blew a bulb after about 1 month, but the bulbs that come in them suuuck. i replaced the bulbs with mtecs and sylvanias (which btw suck for the price).
pros
- look way better than stock
- fit juuust fine
cons
- light output sucks
- no idea how to aim the low beam projector
Old Feb 11, 2004
Well, thanks for the input every one.
I'll just get a new stock light (damged the driver light) instead of a new set of projector lights.
Old Feb 11, 2004
FALKEN's Avatar
Civicforums Junkie
moved to I.C.E. & Electrical...Subforum: Lighting
trevor
Bolt-on Engine Performance
15
Dec 5, 2001 05:37 PM
supercivic01
South
Nov 30, 2001 11:27 AM
meels808
Nov 16, 2001 11:18 AM
