adsf
Old Feb 6, 2004
jttegx's Avatar
OMNES AD UNUM
adsf
asdf
delete me
Old Feb 6, 2004
Connie's Avatar
1. if the peice covering the light is red then there is not much you can do to change the overall color.
2. if you don't mind snipping and reconnecting some wires then it would be fairly easy to change those
3. I agree with you there
4. ?
Old Feb 6, 2004
jttegx's Avatar
OMNES AD UNUM
....4) the 2004 taillights for the coupe are different from 2001-2003. 04 has the circle "uk' style to it. and was wondering if those taillamps will fit my ride?
and this pic. goes to #1. i want sumthin so it can look like this... (possible?)
Old Feb 7, 2004
Cocky's Avatar
Cocky guys kick ass!
there are a few people here with 01-03's with 04 tail lights. i personally don't like them, but you can do it.
Old Feb 7, 2004
PopcornPlaya's Avatar
Electric Boogaloo...
the pic you posted jttegx are european tails, from a uk dm civic coupe. you could possibly get someone to ship you a set from over there. as far as the04 tails on an 01-03, yes, its possible. fitament is the same. the wiring/bulbs is where its different. the 04 tails have 3 bulbs vs the 01-03 have 4 bulbs. the 03's get rid of the sidemarker on the 01-03. you can modify your existing wiring to make it work. the turn signal bulb is a diff size, so you'd have to change it entirely to make it work. there is a topic on this same page that i posted in that covers this. as far as switching the bulbs to make the lamps in a diff place, you'd have to switch the bulb harnesses so that the bulbs will fit in the places you want them (they have screw in plugs that will have to be switched with bulb size so they will fit) thats kind of a vague description, if you need more detail on switching bulb placement, i could provide that.
Old Feb 10, 2004
RiceBuRNeR's Avatar
Turbo Member
Fly has the euro spec tails. PM him to see where he got them.
