Led's Led's Led's
Balut Eating Champ
Led's Led's Led's
Any of ya'll can tell me what kinda LED's and Resistors to replace the HALO's LED's on the angel eye projectors? Whelan's DYI doesn't seem to work for some reason... Thanks!
I used a 2600CDM LED bulb (brightest available) with a 5% 220ohm, 1/2W resistor.
Balut Eating Champ
Why Am I the Only one who's LED's doen't work??? I have the same parts but the LED's lit that I can only see it when enclosed em with in my hands... or in a completely dark area, When you guys solder your LED wire did you use any solder wires? and smaller wires are better?
You should be able to see them fine during the day. Something is wrong. I used the 2600mcd blue LEDs with a 680ohm resistor soldered before the positive lead wire. That's really it. You can have up to three installed like this in series without dimming the light.
Balut Eating Champ
Might have been the soldering job, I soldered one up close to the bulb, any possibilities that I messed that up by soldering up close to the bulb?
Not really. If you held the soldering iron on the leads for more than 1-2 seconds, you may have burned out the resistor or LED.
Remember that not enough resistance will burn out the LED. Too much will just make it dimmer. Extreme heat can change the resistor. You can try just taping the wires together first. Then you know it's your soldering job.
Balut Eating Champ
I soldered it perfectly this time, and used a smaller wire, but still ain't workin...
I think I'll get a 12v connection somewhere else aside from the PARKING LIGHT wires that I've been using... Will that be possible and not blow and or fry anything up?
frank_kleng
Sep 29, 2015 10:55 PM
MamaBear2015
Sep 24, 2015 11:34 AM
Klame9420
Sep 18, 2015 12:37 PM
