Projector headlights, worth it?
Owned By Slo Rex
I have noticed on some of my friends 7th gens the projectors don't light up the street very well at all, but on my friend's 5th gen they work better then stock lights. Do the projectors just suck for 7th gens or does it varie with the brand, and is it worth it to get some?
I bought mine not too long ago and already had to replaces bulbs twice. Its mostly for show, plus they really don't light as well as factory lights, but they still look sweet. They are my first pair so i can't compare to other projectors.
i wont say they all suck, they TYC's are pretty good, but your not going to get that good light output from aftermarket headlights that you would OEM's or JDM's but I guess if you installed a HID kit it would make a difference.
Originally posted by THERING
the HIDS, do they fit or do you have to modify?
I got JDM projectors and used silverstar h1 bulbs at first . The high beam is needless to say blinding in the daylight the low beam is a pain to get adjusted correctly. My stock lights light up more area but the projectors have gave me a broader range in front of me. I am working on the HID conversion either using the h3 or h1 kit and I should be set then . IMO the projectors are better when setup correctly and with good bulbs as well .
End Bringer
h1 hid are overrated in the tycs. lights on a prjector is determined by the lens, if the tyc puts out crap for headlights stock, what makes you think it will do any better with a set of hids
http://www.7thgencivic.com/forums/sh...hreadid=127638
those pics are mostly older, i already have the oem osram bulbs and oem plugs into the setup, just haven't taken pics yet, it's VERY purple when you look at it. it even has a tint of purple on the ground, but it's BRIGHT
jackoncruzpr
Sep 29, 2015 07:59 PM
shaejb15
Sep 12, 2015 01:02 AM
Bricoleur
Sep 9, 2015 12:23 PM
MamaBear2015
Sep 4, 2015 09:04 PM
