Please just help me!?!?
Old Dec 17, 2003
Darkside9360's Avatar
Darkside9360 is an unknown quantity at this point
my fog lights caused my parking lights to blow, and i am gonna replace the fuse tomorrow but i would like to know how to keep it from happening again. i have only had them on for one day. i have the trigger for the fog lights wired up to the parking ligts (the ones in the small circles and i am at a loss to why the blew.
Old Dec 17, 2003
any takers
Old Dec 17, 2003
civic01vtec's Avatar
shouldn't they be wired on their own switch instead of coming on when the parking lights do ?
Old Dec 17, 2003
DistinctiveBP's Avatar
Shows No Remorse
DistinctiveBP is an unknown quantity at this point
thats what i would do and, i would give them their own fuse
Old Dec 17, 2003
they have their own fuse that comes with it. and they have their own switch, it is just that the switch doesnt work unless the parking lights are on (you know just like factory lights.)
Old Dec 17, 2003
what for wires are there.......12v, ground and a power supply.....right ?
the power supply u have run to the parking light trigger u said. But u should be able to turn them on w/o the lights on and the ignition on. Use a test light to find a wire that is hot when the ignition is on.
Old Dec 17, 2003
Mystic3030's Avatar
Yup, i'm an A$$hole.
Use a relay, not a direct wire-in to the parking lights.
Old Dec 17, 2003
what is a relay?
Old Dec 18, 2003
czechcivic's Avatar
czechcivic is an unknown quantity at this point
I had mine connected to the blinker/running light...maybe thats why they only lasted a year or so.There was a switch so they woild only work when I turned the lights on...Is that wrong?
Old Dec 18, 2003
PopcornPlaya's Avatar
Electric Boogaloo...
not sure how my oem ones are wired, but i believe that it is wired into the actual headlamp lowbeam wire. you can only turn them on when the headlights are fully on, and when you brighten your hl, they come off. they were on the car when i bought them from honda. now that i am getting a kit put on, again, they will be gone, again. anyone have any idea how hard it'd be to remove the entire wiring and relays and such from the oem ones? they are in the way when you dont have anything there, just dangling wires.
Old Dec 18, 2003
samlk's Avatar
samlk is an unknown quantity at this point
Fuse
The fuse should have blowed wired that way. The fuse for your
lights is set to power just your parking lights, when you wired
your new fog lights into circuit then the parking light fuse had to
pass enough current for both lights. There is the reason for your
blowen fuse, it didnt have enough current rating to pass the current
load.........
Samlk
